Ana içeriğe geç
Hamilton Beach 64650 Quick Burst Button Replacement
Neye ihtiyacın var
    1. Hamilton Beach 64650 Quick Burst Button Replacement, Motor: adım 1, 3 resimden 1. Hamilton Beach 64650 Quick Burst Button Replacement, Motor: adım 1, 3 resimden 2. Hamilton Beach 64650 Quick Burst Button Replacement, Motor: adım 1, 3 resimden 3.
      • Flip the handle on its side. Remove five 3.8 mm Philips #2 screws shown and set aside them aside.
      FixBot'a Sor
      Yorum Ekle
    2. Hamilton Beach 64650 Quick Burst Button Replacement: adım 2, 3 resimden 1. Hamilton Beach 64650 Quick Burst Button Replacement: adım 2, 3 resimden 2. Hamilton Beach 64650 Quick Burst Button Replacement: adım 2, 3 resimden 3.
      • Remove the four 8.6 mm Philips #2 screws securing the motor mount and place them aside.
      FixBot'a Sor
      Yorum Ekle
    3. Hamilton Beach 64650 Quick Burst Button Replacement: adım 3, 3 resimden 1. Hamilton Beach 64650 Quick Burst Button Replacement: adım 3, 3 resimden 2. Hamilton Beach 64650 Quick Burst Button Replacement: adım 3, 3 resimden 3.
      • Carefully pull the motor block out of the case.
      • Collect the two spring located on top of the white beater gears. The springs are held in place with compression, and may fall into the case when the motor is moved.
      • Handle the wires with care to ensure you do not break any of them.
      FixBot'a Sor
      Yorum Ekle
    4. Hamilton Beach 64650 Quick Burst Button Replacement: adım 4, 3 resimden 1. Hamilton Beach 64650 Quick Burst Button Replacement: adım 4, 3 resimden 2. Hamilton Beach 64650 Quick Burst Button Replacement: adım 4, 3 resimden 3.
      • Desolder the six wires connected to the motor using this guide.
      • Make sure to note colors when you disconnect them and remember where to reconnect them later.
      FixBot'a Sor
      Yorum Ekle
    5. Hamilton Beach 64650 Quick Burst Button Replacement: adım 5, 2 resimden 1. Hamilton Beach 64650 Quick Burst Button Replacement: adım 5, 2 resimden 2.
      • Once disconnected, the motor will slide out easily.
      FixBot'a Sor
      Yorum Ekle
    1. Hamilton Beach 64650 Quick Burst Button Replacement, Quick Burst Button: adım 6, 3 resimden 1. Hamilton Beach 64650 Quick Burst Button Replacement, Quick Burst Button: adım 6, 3 resimden 2. Hamilton Beach 64650 Quick Burst Button Replacement, Quick Burst Button: adım 6, 3 resimden 3.
      • Remove the seven 1.3 mm Philips #2 screws that attach the motor casing to the mixer handle and set them aside.
      FixBot'a Sor
      Yorum Ekle
    2. Hamilton Beach 64650 Quick Burst Button Replacement: adım 7, 3 resimden 1. Hamilton Beach 64650 Quick Burst Button Replacement: adım 7, 3 resimden 2. Hamilton Beach 64650 Quick Burst Button Replacement: adım 7, 3 resimden 3.
      • Use a plastic opening tool to take off the handle's cap by loosening both ends and then sliding the tool to the middle of the handle.
      FixBot'a Sor
      Yorum Ekle
    3. Hamilton Beach 64650 Quick Burst Button Replacement: adım 8, 2 resimden 1. Hamilton Beach 64650 Quick Burst Button Replacement: adım 8, 2 resimden 2.
      • Lift the handle cap upward once it is loose.
      • Be careful when you remove the handle cap as the quick burst button likes to fly away.
      • Replace the button assembly as needed.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Gwen Davis
519 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 7-3, Catania Spring 2016 UMass Dartmouth, Team 7-3, Catania Spring 2016 üyesi
UMASSD-CATANIA-S16S7G3
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 28
Her zaman: 984
