Ana içeriğe geç
Hamilton Beach 70730 Drive Shaft Replacement
Mack Bernard
Mack Bernard ve 6 diğer katkıda bulunanlar
En son May 7, 2024 tarihinde güncellendi
3 - 5 dakika
Orta
Eksik Adımlar
The drive shaft is essential and may possibly have a stripped gear, causing the blade not to turn. There are several steps in order to take this out and replace it. Beware of lubricant along the bottom of it.
Neye ihtiyacın var
  1. Hamilton Beach 70730 Drive Shaft Replacement, Bowl: adım 1, 1 resimden 1.
    • Unscrew the cover by turning it counterclockwise.
  2. Hamilton Beach 70730 Drive Shaft Replacement: adım 2, 1 resimden 1.
    • Grab the scraper by the midsection to remove.
  3. Hamilton Beach 70730 Drive Shaft Replacement: adım 3, 1 resimden 1.
    • Carefully remove the blades by lifting them off of the blade shaft.
  4. Hamilton Beach 70730 Drive Shaft Replacement: adım 4, 1 resimden 1.
    • Rotate the bowl counterclockwise to release it from the base.
  5. Hamilton Beach 70730 Drive Shaft Replacement: adım 5, 1 resimden 1.
    • Make sure there is no food or grime along the outside of the bowl or the base.
  6. Hamilton Beach 70730 Drive Shaft Replacement, Drive Shaft: adım 6, 1 resimden 1.
    • Using the metal spudger, remove the four adhesive plastic covers that hide the screws.
    • These covers are adhered to the screws.
  7. Hamilton Beach 70730 Drive Shaft Replacement: adım 7, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Remove any excess glue that is adhered to the screws with the precision tweezers.
  8. Hamilton Beach 70730 Drive Shaft Replacement: adım 8, 1 resimden 1.
    • Using a JIS #1 driver, remove the four 10 mm screws.
  9. Hamilton Beach 70730 Drive Shaft Replacement: adım 9, 1 resimden 1.
    • Lift the driveshaft off of the base.
Sonuç
Mack Bernard
597 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-4, Isaacson Spring 2016 UMass Dartmouth, Team 2-4, Isaacson Spring 2016 üyesi
UMASSD-ISAACSON-S16S2G4
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 1,161
