Ana içeriğe geç
Hamilton Beach 70740 Power Cord Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
    1. Hamilton Beach 70740 Power Cord Replacement, Base Removal: adım 1, 3 resimden 1. Hamilton Beach 70740 Power Cord Replacement, Base Removal: adım 1, 3 resimden 2. Hamilton Beach 70740 Power Cord Replacement, Base Removal: adım 1, 3 resimden 3.
      • Hold the food processor upside down and remove the two screws indicated with a screwdriver. Once unscrewed, remove the two rubber suction pads.
      FixBot'a Sor
      Yorum Ekle
    2. Hamilton Beach 70740 Power Cord Replacement: adım 2, 2 resimden 1. Hamilton Beach 70740 Power Cord Replacement: adım 2, 2 resimden 2.
      • Use a spudger to remove the 4 rubber base pads located at the corners of the device.
      FixBot'a Sor
      Yorum Ekle
    3. Hamilton Beach 70740 Power Cord Replacement: adım 3, 1 resimden 1.
      • Unscrew all 4 screws that are located beneath the pads with a screwdriver and remove the plastic grey base.
      FixBot'a Sor
      Yorum Ekle
    4. Hamilton Beach 70740 Power Cord Replacement: adım 4, 1 resimden 1.
      • Remove the screws indicated with a screw driver.
      FixBot'a Sor
      Yorum Ekle
    5. Hamilton Beach 70740 Power Cord Replacement: adım 5, 1 resimden 1.
      • Remove the two screws behind the knob with a screwdriver.
      FixBot'a Sor
      Yorum Ekle
    1. Hamilton Beach 70740 Power Cord Replacement, Motor/Cord: adım 6, 1 resimden 1.
      • Use a regular nylon spudger to remove the plastic caps at these locations with moderate pressure.
      • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
      • Apply pressure at the edge of the plastic cap circles. Apply stress elsewhere may damage the device.
      • Note that the plastic caps are glued
      FixBot'a Sor
      Yorum Ekle
    2. Hamilton Beach 70740 Power Cord Replacement: adım 7, 1 resimden 1.
      • Remove the 4 screws located under the plastic caps with a screw driver.
      FixBot'a Sor
      Yorum Ekle
    3. Hamilton Beach 70740 Power Cord Replacement: adım 8, 2 resimden 1. Hamilton Beach 70740 Power Cord Replacement: adım 8, 2 resimden 2.
      • Lift and remove the plastic gears at the center of the device.
      • Remove any grease residue underneath the plastic gears.
      FixBot'a Sor
      Yorum Ekle
    4. Hamilton Beach 70740 Power Cord Replacement: adım 9, 2 resimden 1. Hamilton Beach 70740 Power Cord Replacement: adım 9, 2 resimden 2.
      • Remove the remaining screws to unhinge the motor located at the center of the device using a screw driver.
      FixBot'a Sor
      Yorum Ekle
    1. Hamilton Beach 70740 Power Cord Replacement, Power Cord: adım 10, 1 resimden 1.
      • Solder the highlighted section of the power cord, and undo the wiring. Using soldering wire connect a new line with the soldering iron.
      • Learn more about soldering here.
      FixBot'a Sor
      Yorum Ekle
    2. Hamilton Beach 70740 Power Cord Replacement: adım 11, 1 resimden 1.
      • Connect the other end of your power cord to the motor terminal.
      FixBot'a Sor
      Yorum Ekle
Sonuç
David Gedeon
806 İtibar
6 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-1, Baechle Fall 2015 IUPUI, Team 1-1, Baechle Fall 2015 üyesi
IUPUI-BAECHLE-F15S1G1
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 21
Her zaman: 572
