Giriş
The fix is needed when the motor is worn out and overheats when used. To replace the old motor for a new one a Philips screwdriver (2mm), Tri-head screwdriver (2mm) and a soldering iron are needed. Also, you will need a new motor.
Neye ihtiyacın var
Bir başkası bu kılavuzu tamamladı.
1Rehber Yorum
Model WST2024E blender counter model. Heavey glass 1.5 Liter. 3 SPD. plus pulse.
Need to either replace brushes or motor
