Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Heat Gun cihazınızı onarmak için, servis kılavuzumuzu kullanın.
    1. Heat Gun Disassembly, Overall structure: adım 1, 3 resimden 1. Heat Gun Disassembly, Overall structure: adım 1, 3 resimden 2. Heat Gun Disassembly, Overall structure: adım 1, 3 resimden 3.
      • All screws on one side for ease of assembly
      • Wire has a stiffener for protection
      • Switch is placed on handle in an ergonomic position so that one hand operation is easy
      • The back of the handle and the back of the body are in a straight plane in order to place the gun in vertical position after operation to cool it down
      • Vents are placed in the top part to facilitate air flow
      • The product is colored in industrial orange to be easily visible and distinguishable from the work environment
      FixBot'a Sor
      Yorum Ekle
    2. Heat Gun Disassembly, Plastic detailing: adım 2, 3 resimden 1. Heat Gun Disassembly, Plastic detailing: adım 2, 3 resimden 2. Heat Gun Disassembly, Plastic detailing: adım 2, 3 resimden 3.
      • All plastic detailing is made to have no overhangs
      • screwing details are used in order to locate the two half together without external jig
      • A lip joint is used in order to secure the assembly and also make it impermeable and rigid
      FixBot'a Sor
      Yorum Ekle
    3. Heat Gun Disassembly, Electrical component placement: adım 3, 2 resimden 1. Heat Gun Disassembly, Electrical component placement: adım 3, 2 resimden 2.
      • All electrical components are connected using connectors instead of direct soldering to facilitate easy replacement
      • The components have negative placers inbuilt in the in plastic injection mold
      • The electrical components are placed in order to prevent shorting
      FixBot'a Sor
      Yorum Ekle
    4. Heat Gun Disassembly, Heat component placements: adım 4, 3 resimden 1. Heat Gun Disassembly, Heat component placements: adım 4, 3 resimden 2. Heat Gun Disassembly, Heat component placements: adım 4, 3 resimden 3.
      • All heat components are suspended in order to prevent the heated elements to come in contact with plastic parts
      • The blower chamber is designed in heat resistant pet in order to prevent it from deformation
      • The motor and the blower fan has a press fit
      FixBot'a Sor
      Yorum Ekle
    5. Heat Gun Disassembly, Heat tube: adım 5, 2 resimden 1. Heat Gun Disassembly, Heat tube: adım 5, 2 resimden 2.
      • The heat tube is using mica support and kapton insulation
      • The external heat tube is stainless steel to prevent degradation of the tube.
      • The heat coil is used as a resistor to step down voltage for motor and hence it has a dual perpose
      • The heat coil is made of nichrome wire.
      FixBot'a Sor
      Yorum Ekle
    6. Heat Gun Disassembly, Detail assembly: adım 6, 3 resimden 1. Heat Gun Disassembly, Detail assembly: adım 6, 3 resimden 2. Heat Gun Disassembly, Detail assembly: adım 6, 3 resimden 3.
      • Minimum number of screws (variety) are used and all screws are self tapping in order to eliminate the use of nuts and loose parts.
      • Assembly has location pins to align circular parts in a fixed orientation.
      • Heat rings are used in order to over heating
      FixBot'a Sor
      Yorum Ekle
varunsanghvi2000
192 İtibar
1 Kılavuz yazıldı
1Rehber Yorum
Any idea where I can get a replacement for the plastic fan? It just fell off and melted and there doesn’t seem to be any information on the net. It’s a simple part. I’ve only used the gun a half a dozen times but it’s been years since it was purchased. Your instructions were helpful.
C Richards - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 23
Son 30 gün: 91
Her zaman: 10,297
