Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
There are many different components to a dryer and finding the exact issue was difficult. The internet didn't provide a direct answer. So after reading on several different forums, I found I needed to use a voltmeter to find the bad component. Once I found it I simply looked up the product number and bam, had a working dryer in no time.
First of all we need to make room behind the dryer. To do this a dolly is recommended since its about 250lbs and can definitely scratch the floor if drug. Pull the machine out slowly until there is room to fit behind and still have arm space.
The dryer vent, hot/cold water and drainage pipes can remain attached. But for safety unplugging the machine is mandatory. The plug is big and may require a little extra force to remove.
