Ana içeriğe geç
Heyday Suitcase Turntable Baseboard Removal
Caroline D'Amato
Caroline D'Amato ve 3 diğer katkıda bulunanlar
En son December 29, 2022 tarihinde güncellendi
10 - 20 dakika
Kolay
Daha Fazla Görsel Gerekli
In order to access the internal components of the Heyday Suitcase Turntable, you will need to remove the baseboard. The baseboard is what the platter sits on, as well as the arm and all of the external components of the device.
Before beginning this guide, turn off the record player and unplug the power cord.
Neye ihtiyacın var
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. Heyday Suitcase Turntable Baseboard Removal, Baseboard: adım 1, 1 resimden 1.
    • Use a Phillips #2 screwdriver to remove the four screws on each corner of the baseboard.
  2. Heyday Suitcase Turntable Baseboard Removal: adım 2, 1 resimden 1.
    • Use a metal spudger to pry the baseboard off of the case.
    • Be cautious of the cords and circuit located underneath the knob and the lever. Don't pull or yank the baseboard off.
  3. Heyday Suitcase Turntable Baseboard Removal: adım 3, 2 resimden 1. Heyday Suitcase Turntable Baseboard Removal: adım 3, 2 resimden 2.
    • Disconnect the cords from the circuit board.
    • Take a picture beforehand so it's easier to put them back during reassembly.
    • Remove the baseboard.
Sonuç
To reassemble your device, follow these instructions in reverse order. Reconnect the cords to their appropriate ports on the circuit board, then replace the baseboard by tightening the four screws.
Caroline D'Amato
565 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-1, Petersen Fall 2022 UMass Dartmouth, Team 2-1, Petersen Fall 2022 üyesi
UMASSD-PETERSEN-F22S2G1
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 187
