Ana içeriğe geç
Heyday Suitcase Turntable Needle Replacement
  1. Heyday Suitcase Turntable Needle Replacement, Needle: adım 1, 2 resimden 1. Heyday Suitcase Turntable Needle Replacement, Needle: adım 1, 2 resimden 2.
    • Before you begin the repair, turn off the record player and unplug the power cord.
    • Remove cartridge lock by pushing inwards (towards the needle arm, while lightly squeezing the sides by hand. Then pull downwards and towards you to disengage the locking hook. This will unhook the lock between cartridge and base.
    FixBot'a Sor
    Yorum Ekle
  2. Heyday Suitcase Turntable Needle Replacement: adım 2, 1 resimden 1.
    • Disconnect the wires from the cartridge.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Replace the needle by clipping it back onto the cartridge and then reconnect the wires to the correct part of the cartridge.
Caroline D'Amato
565 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-1, Petersen Fall 2022 UMass Dartmouth, Team 2-1, Petersen Fall 2022 üyesi
UMASSD-PETERSEN-F22S2G1
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 45
Her zaman: 1,146
