Ana içeriğe geç
Heyday Suitcase Turntable Volume Knob Replacement
Neye ihtiyacın var
  1. Heyday Suitcase Turntable Volume Knob Replacement, Baseboard: adım 1, 1 resimden 1.
    • Use a Phillips #2 screwdriver to remove the four screws on each corner of the baseboard.
    FixBot'a Sor
    Yorum Ekle
  2. Heyday Suitcase Turntable Volume Knob Replacement: adım 2, 1 resimden 1.
    • Use a metal spudger to pry the baseboard off of the case.
    • Be cautious of the cords and circuit located underneath the knob and the lever. Don't pull or yank the baseboard off.
    FixBot'a Sor
    Yorum Ekle
  3. Heyday Suitcase Turntable Volume Knob Replacement: adım 3, 2 resimden 1. Heyday Suitcase Turntable Volume Knob Replacement: adım 3, 2 resimden 2.
    • Disconnect the cords from the circuit board.
    • Take a picture beforehand so it's easier to put them back during reassembly.
    • Remove the baseboard.
    FixBot'a Sor
    Yorum Ekle
  4. Heyday Suitcase Turntable Volume Knob Replacement, Volume Knob: adım 4, 1 resimden 1.
    • Use a metal spudger to pry the volume knob off of the baseboard.
    FixBot'a Sor
    Yorum Ekle
  5. Heyday Suitcase Turntable Volume Knob Replacement: adım 5, 2 resimden 1. Heyday Suitcase Turntable Volume Knob Replacement: adım 5, 2 resimden 2.
    • Use your fingers to unscrew the nut securing the volume knob.
    FixBot'a Sor
    Yorum Ekle
  6. Heyday Suitcase Turntable Volume Knob Replacement: adım 6, 1 resimden 1.
    • Use a metal spudger to pry the power knob off of the baseboard.
    FixBot'a Sor
    Yorum Ekle
  7. Heyday Suitcase Turntable Volume Knob Replacement: adım 7, 2 resimden 1. Heyday Suitcase Turntable Volume Knob Replacement: adım 7, 2 resimden 2.
    • Use your fingers to unscrew the nut securing the power knob.
    FixBot'a Sor
    Yorum Ekle
  8. Heyday Suitcase Turntable Volume Knob Replacement: adım 8, 1 resimden 1.
    • Pull the circuit board down from the baseboard to separate them.
    FixBot'a Sor
    Yorum Ekle
  9. Heyday Suitcase Turntable Volume Knob Replacement: adım 9, 1 resimden 1.
    • To release the volume knob, desolder each of the eight solder joints.
    • Make sure to take proper safety precautions while operating soldering iron. For a review, take a look at the guide on How to Solder and Desolder Connections.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Caroline D'Amato
565 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-1, Petersen Fall 2022 UMass Dartmouth, Team 2-1, Petersen Fall 2022 üyesi
UMASSD-PETERSEN-F22S2G1
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 22
Her zaman: 409
