Ana içeriğe geç
Heyday Suitcase Turntable Volume Knob Replacement
Neye ihtiyacın var
  1. Heyday Suitcase Turntable Volume Knob Replacement, Baseboard: adım 1, 1 resimden 1.
    • Use a Phillips #2 screwdriver to remove the four screws on each corner of the baseboard.
  2. Heyday Suitcase Turntable Volume Knob Replacement: adım 2, 1 resimden 1.
    • Use a metal spudger to pry the baseboard off of the case.
    • Be cautious of the cords and circuit located underneath the knob and the lever. Don't pull or yank the baseboard off.
  3. Heyday Suitcase Turntable Volume Knob Replacement: adım 3, 2 resimden 1. Heyday Suitcase Turntable Volume Knob Replacement: adım 3, 2 resimden 2.
    • Disconnect the cords from the circuit board.
    • Take a picture beforehand so it's easier to put them back during reassembly.
    • Remove the baseboard.
  4. Heyday Suitcase Turntable Volume Knob Replacement, Volume Knob: adım 4, 1 resimden 1.
    • Use a metal spudger to pry the volume knob off of the baseboard.
  5. Heyday Suitcase Turntable Volume Knob Replacement: adım 5, 2 resimden 1. Heyday Suitcase Turntable Volume Knob Replacement: adım 5, 2 resimden 2.
    • Use your fingers to unscrew the nut securing the volume knob.
  6. Heyday Suitcase Turntable Volume Knob Replacement: adım 6, 1 resimden 1.
    • Use a metal spudger to pry the power knob off of the baseboard.
  7. Heyday Suitcase Turntable Volume Knob Replacement: adım 7, 2 resimden 1. Heyday Suitcase Turntable Volume Knob Replacement: adım 7, 2 resimden 2.
    • Use your fingers to unscrew the nut securing the power knob.
  8. Heyday Suitcase Turntable Volume Knob Replacement: adım 8, 1 resimden 1.
    • Pull the circuit board down from the baseboard to separate them.
  9. Heyday Suitcase Turntable Volume Knob Replacement: adım 9, 1 resimden 1.
    • To release the volume knob, desolder each of the eight solder joints.
    • Make sure to take proper safety precautions while operating soldering iron. For a review, take a look at the guide on How to Solder and Desolder Connections.
Sonuç
Caroline D'Amato
565 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-1, Petersen Fall 2022 UMass Dartmouth, Team 2-1, Petersen Fall 2022 üyesi
UMASSD-PETERSEN-F22S2G1
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 197
