Ana içeriğe geç
Hisense Sero 8 Motherboard Replacement
Neye ihtiyacın var
  1. Hisense Sero 8 Motherboard Replacement, Motherboard: adım 1, 3 resimden 1. Hisense Sero 8 Motherboard Replacement, Motherboard: adım 1, 3 resimden 2. Hisense Sero 8 Motherboard Replacement, Motherboard: adım 1, 3 resimden 3.
    • Remove the back cover of the device using the plastic opening tool.
    • Pry open a corner of the device, then continue down the side with the tool to open the device.
  2. Hisense Sero 8 Motherboard Replacement: adım 2, 2 resimden 1. Hisense Sero 8 Motherboard Replacement: adım 2, 2 resimden 2.
    • Remove the black tape located to the left of the device.
    • Remove the clear tape directly below the camera.
  3. Hisense Sero 8 Motherboard Replacement: adım 3, 1 resimden 1.
    • Remove the seven 4.43mm screws located at the top of the device using the Phillips #00 screwdriver.
    • There is no need to remove the bottom two screws holding the speakers in place.
  4. Hisense Sero 8 Motherboard Replacement: adım 4, 1 resimden 1.
    • Unlock the three ribbon cable connector latches to remove the cables.
  5. Hisense Sero 8 Motherboard Replacement: adım 5, 3 resimden 1. Hisense Sero 8 Motherboard Replacement: adım 5, 3 resimden 2. Hisense Sero 8 Motherboard Replacement: adım 5, 3 resimden 3.
    • Be cautious of the extremely hot tip of the soldering iron.
    • Desolder the red, black, and yellow wires to remove the motherboard. Take a look at this guide to learn how to solder and desolder connections.
    • Desolder the black wire located on the top left of the device.
    • Once desoldered, carefully lift the motherboard out of the device.
Sonuç
Katharina
506 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-2, Leahy Winter 2015 USF Tampa, Team 1-2, Leahy Winter 2015 üyesi
USFT-LEAHY-W15S1G2
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 15
Her zaman: 1,356
