Ana içeriğe geç
Holmes HEH8031 Fan Replacement
Neye ihtiyacın var
  1. Holmes HEH8031 Fan Replacement, Housing: adım 1, 1 resimden 1.
    • Ensure the device is unplugged from the wall outlet.
  2. Holmes HEH8031 Fan Replacement: adım 2, 1 resimden 1.
    • Remove eight 12-mm Phillips #2 screws from the back cover.
  3. Holmes HEH8031 Fan Replacement: adım 3, 2 resimden 1. Holmes HEH8031 Fan Replacement: adım 3, 2 resimden 2.
    • Turn heater over so the controls are facing up.
    • Lift the front housing away from the back of the fan and slowly fold the front housing back down to the floor.
    • Internal wires are connected to both halves of the housing. Be careful when separating the housing.
  4. Holmes HEH8031 Fan Replacement, Circuit Board Removal: adım 4, 1 resimden 1.
    • Remove four 12mm Phillips #2 screws from the circuit board.
  5. Holmes HEH8031 Fan Replacement, Circuit Board: adım 5, 3 resimden 1. Holmes HEH8031 Fan Replacement, Circuit Board: adım 5, 3 resimden 2. Holmes HEH8031 Fan Replacement, Circuit Board: adım 5, 3 resimden 3.
    • Desolder the BLACK wires from the "AC-L" point and "T/S" point.
    • Learn how to solder and desolder connections here!
    • Desolder the WHITE wire from the "AC-N" point.
    • Desolder the RED wire from the "FAN-RED".
    • Desolder the GREY wire from the "24V" point.
    • Desolder the BROWN wires from "HEAT1," and "HEAT2" points.
    • Be sure to use desoldering wick when you remove the wire connections.
  6. Holmes HEH8031 Fan Replacement: adım 6, 2 resimden 1. Holmes HEH8031 Fan Replacement: adım 6, 2 resimden 2.
    • Desolder the WHITE connector (attached to the GRAY wire coming of the thermostat) from the "NTC101" point.
  7. Holmes HEH8031 Fan Replacement, Fan: adım 7, 1 resimden 1.
    • Remove two Phillips #2 12mm screws from housing
  8. Holmes HEH8031 Fan Replacement: adım 8, 1 resimden 1.
    • Remove zip tie from wire with pliers
  9. Holmes HEH8031 Fan Replacement: adım 9, 1 resimden 1.
    • Separate fan assembly from heating coil
Sonuç
Bir başkası bu kılavuzu tamamladı.
Torben Eid
1 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 2-1, Baechle Fall 2016 IUPUI, Team 2-1, Baechle Fall 2016 üyesi
IUPUI-BAECHLE-F16S2G1
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 318
