Ana içeriğe geç
Honda 3000 Watt Inverter Generator EU3000IS1AWK Battery Replacement
Arthur Shi
Arthur Shi
En son August 31, 2020 tarihinde güncellendi
6 - 10 dakika
Orta
This guide shows how to remove and replace the starter battery for the Honda EU3000IS1AWK 3000 watt generator.
Some images in this guide may show the lower plate removed from the generator. You do not need to remove the lower plate for this procedure.
Before you begin, make sure the generator is switched off and the generator is cool to the touch.
  1. Honda 3000 Watt Inverter Generator EU3000IS1AWK Battery Replacement, Remove the front cover: adım 1, 3 resimden 1. Honda 3000 Watt Inverter Generator EU3000IS1AWK Battery Replacement, Remove the front cover: adım 1, 3 resimden 2. Honda 3000 Watt Inverter Generator EU3000IS1AWK Battery Replacement, Remove the front cover: adım 1, 3 resimden 3.
    • Use a 10 mm socket to remove the four capped nuts securing the front cover.
    • Remove the front cover.
  2. Honda 3000 Watt Inverter Generator EU3000IS1AWK Battery Replacement, Remove the battery: adım 2, 1 resimden 1.
    • Use an 8 mm socket to disconnect the battery wires from the battery terminals.
    • Disconnect the black negative cable first to prevent the risk of shorting the battery.
    • During reassembly, connect the black negative cable first. Make sure you reconnect the wires in the correct polarity.
  3. Honda 3000 Watt Inverter Generator EU3000IS1AWK Battery Replacement: adım 3, 2 resimden 1. Honda 3000 Watt Inverter Generator EU3000IS1AWK Battery Replacement: adım 3, 2 resimden 2.
    • Unclip the battery strap from the lower plate.
  4. Honda 3000 Watt Inverter Generator EU3000IS1AWK Battery Replacement: adım 4, 1 resimden 1.
    • Remove the battery.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Arthur Shi
282.961 İtibar
587 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
119 Üyeler
19.526 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 30
Son 30 gün: 112
Her zaman: 8,401
