Ana içeriğe geç
Honda Rear Tine Tiller FRC800K1A Rotary Tines Replacement
Neye ihtiyacın var
  1. Honda Rear Tine Tiller FRC800K1A Rotary Tines Replacement, Disconnect the spark plug wire: adım 1, 2 resimden 1. Honda Rear Tine Tiller FRC800K1A Rotary Tines Replacement, Disconnect the spark plug wire: adım 1, 2 resimden 2.
    • Before you begin the repair, disconnect the spark plug wire.
    • Firmly grip the base of the connector and pull it away from the spark plug to disconnect it.
  2. Honda Rear Tine Tiller FRC800K1A Rotary Tines Replacement, Turn off the fuel valve: adım 2, 1 resimden 1.
    • Flip the fuel valve switch to the off position.
  3. Honda Rear Tine Tiller FRC800K1A Rotary Tines Replacement, Remove the side tine guards: adım 3, 2 resimden 1. Honda Rear Tine Tiller FRC800K1A Rotary Tines Replacement, Remove the side tine guards: adım 3, 2 resimden 2.
    • Use a 12 mm socket and wrench to remove the six sets of side guard bolts and nuts, three on each side.
  4. Honda Rear Tine Tiller FRC800K1A Rotary Tines Replacement: adım 4, 2 resimden 1. Honda Rear Tine Tiller FRC800K1A Rotary Tines Replacement: adım 4, 2 resimden 2.
    • Slide the side guard off of the curved main guard to remove.
    • Repeat the same process on the opposite side.
  5. Honda Rear Tine Tiller FRC800K1A Rotary Tines Replacement, Remove the rotary tine: adım 5, 1 resimden 1.
    • Use a 14 mm socket to remove the two rotary tine retaining bolts.
    • Repeat the same process on the opposite rotary tine.
  6. Honda Rear Tine Tiller FRC800K1A Rotary Tines Replacement: adım 6, 3 resimden 1. Honda Rear Tine Tiller FRC800K1A Rotary Tines Replacement: adım 6, 3 resimden 2. Honda Rear Tine Tiller FRC800K1A Rotary Tines Replacement: adım 6, 3 resimden 3.
    • Slide the rotary tine off its axle to remove it.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Carsten Frauenheim
136.342 İtibar
371 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.583 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 15
Son 30 gün: 74
Her zaman: 2,128
