Ana içeriğe geç
Honda Rear Tine Tiller FRC800K1A V-Belt Replacement
Neye ihtiyacın var
  1. Honda Rear Tine Tiller FRC800K1A V-Belt Replacement, Disconnect the spark plug wire: adım 1, 2 resimden 1. Honda Rear Tine Tiller FRC800K1A V-Belt Replacement, Disconnect the spark plug wire: adım 1, 2 resimden 2.
    • Before you begin the repair, disconnect the spark plug wire.
    • Firmly grip the base of the connector and pull it away from the spark plug to disconnect it.
  2. Honda Rear Tine Tiller FRC800K1A V-Belt Replacement, Turn off the fuel valve: adım 2, 1 resimden 1.
    • Flip the fuel valve switch to the off position.
  3. Honda Rear Tine Tiller FRC800K1A V-Belt Replacement, Remove outer belt cover: adım 3, 1 resimden 1.
    • Use a 14 mm socket to remove the bolt securing the outer belt cover.
  4. Honda Rear Tine Tiller FRC800K1A V-Belt Replacement: adım 4, 3 resimden 1. Honda Rear Tine Tiller FRC800K1A V-Belt Replacement: adım 4, 3 resimden 2. Honda Rear Tine Tiller FRC800K1A V-Belt Replacement: adım 4, 3 resimden 3.
    • Tilt the outer belt cover down and pull it off of the lip on the inner belt cover to remove it.
  5. Honda Rear Tine Tiller FRC800K1A V-Belt Replacement, Remove the V-belt: adım 5, 3 resimden 1. Honda Rear Tine Tiller FRC800K1A V-Belt Replacement, Remove the V-belt: adım 5, 3 resimden 2. Honda Rear Tine Tiller FRC800K1A V-Belt Replacement, Remove the V-belt: adım 5, 3 resimden 3.
    • Push the V-belt towards the transmission pulley to release tension.
    • Slip the V-belt off of the groove in the pulley.
  6. Honda Rear Tine Tiller FRC800K1A V-Belt Replacement: adım 6, 3 resimden 1. Honda Rear Tine Tiller FRC800K1A V-Belt Replacement: adım 6, 3 resimden 2. Honda Rear Tine Tiller FRC800K1A V-Belt Replacement: adım 6, 3 resimden 3.
    • Pull the V-belt down and out of the way of the two-prong belt guide.
    • Push the V-belt around and off of the motor pulley to remove.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Carsten Frauenheim
136.576 İtibar
371 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.656 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 42
Her zaman: 1,765
