Ana içeriğe geç
Honda civic 2016 Keyless Remote Battery Replacement
Neye ihtiyacın var
  1. Honda civic 2016 Keyless Remote Battery Replacement, Let's get started: adım 1, 2 resimden 1. Honda civic 2016 Keyless Remote Battery Replacement, Let's get started: adım 1, 2 resimden 2.
    • Make sure to have replacement battery ready. You will need 1 pc of CR 2032 Lithium battery.
    • Remove the metal key by sliding the switch on the back of the remote and pulling the key out.
    "Without battery, the car cannot be started."
    That statement is not accurate. For the 2016 Honda Civic coupe 1.5t exl the civics key fob has an RFID chip. If the fob battery is dead set the fob up in the digital instrument panel area behind the steering wheel and the car will start.
    Helix Helix - Yanıt
  2. Honda civic 2016 Keyless Remote Battery Replacement, Cracking it open: adım 2, 3 resimden 1. Honda civic 2016 Keyless Remote Battery Replacement, Cracking it open: adım 2, 3 resimden 2. Honda civic 2016 Keyless Remote Battery Replacement, Cracking it open: adım 2, 3 resimden 3.
    • After removing the key, you will see 2 plastic bars. This is a place where you can split the remote open.
    • The manufacturer recommeded using a coin but any hard tool or even the key itself will work as well.
    • The manufacturer recommended using a cloth covering your coin/ tool to prevent it from denting the plastic bars.
  3. Honda civic 2016 Keyless Remote Battery Replacement, Removing the battery: adım 3, 3 resimden 1. Honda civic 2016 Keyless Remote Battery Replacement, Removing the battery: adım 3, 3 resimden 2. Honda civic 2016 Keyless Remote Battery Replacement, Removing the battery: adım 3, 3 resimden 3.
    • Now you can gently pry it open
    • Removing the old battery from the left side.
    • Remember that the + side of the battery is facing up.
  4. Honda civic 2016 Keyless Remote Battery Replacement, Inserting a new battery: adım 4, 2 resimden 1. Honda civic 2016 Keyless Remote Battery Replacement, Inserting a new battery: adım 4, 2 resimden 2.
    • Inserting a new CR 2032 battery from the right side first and then press the battery down. It should make a good 'click' sound
    • Again, make sure the + side of the battery is facing upward.
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
Anan Venasakulchai
861 İtibar
2 adet Kılavuz yazıldı
Ekip
Finn Store Finn Store üyesi
Business
1 Üye
7 adet Kılavuz yazıldı
1Rehber Yorum
Super Anleitung mit sehr guten Fotos - vielen Dank!
Philipp Glück - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 95
Son 30 gün: 545
Her zaman: 56,617
