Ana içeriğe geç
Hott T725-8G Screen/Display Replacement
Neye ihtiyacın var
    1. Hott T725-8G Screen/Display Replacement, Screen/Display: adım 1, 1 resimden 1.
      • Use the Metal Spudger tool and your fingers to peel off any existing screen protector.
      FixBot'a Sor
      Yorum Ekle
    2. Hott T725-8G Screen/Display Replacement: adım 2, 1 resimden 1.
      • Remove black electrical tape to release the sensor and ribbon wires connecting the camera to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. Hott T725-8G Screen/Display Replacement: adım 3, 1 resimden 1.
      • Dislodge the sensor from the front panel.
      FixBot'a Sor
      Yorum Ekle
    4. Hott T725-8G Screen/Display Replacement: adım 4, 2 resimden 1. Hott T725-8G Screen/Display Replacement: adım 4, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Use a pair of Precision Tweezers to squeeze the clip of the ribbon wire to release it.
      FixBot'a Sor
      Yorum Ekle
    5. Hott T725-8G Screen/Display Replacement: adım 5, 3 resimden 1. Hott T725-8G Screen/Display Replacement: adım 5, 3 resimden 2. Hott T725-8G Screen/Display Replacement: adım 5, 3 resimden 3.
      • Using a pair of the Precision Tweezers, remove the ribbon wire from the clip.
      FixBot'a Sor
      Yorum Ekle
    6. Hott T725-8G Screen/Display Replacement: adım 6, 1 resimden 1.
      • Follow the guide to remove the motherboard from the back of the display.
      FixBot'a Sor
      Yorum Ekle
    7. Hott T725-8G Screen/Display Replacement: adım 7, 1 resimden 1.
      • Follow the guide to remove the battery from the back of the display.
      FixBot'a Sor
      Yorum Ekle
    8. Hott T725-8G Screen/Display Replacement: adım 8, 1 resimden 1.
      • With the motherboard and battery detached, use the Metal Spudger tool to gently remove the display from the front panel.
      FixBot'a Sor
      Yorum Ekle
    9. Hott T725-8G Screen/Display Replacement: adım 9, 1 resimden 1.
      • Remove Digitizer Panel from the front panel.
      FixBot'a Sor
      Yorum Ekle
    10. Hott T725-8G Screen/Display Replacement: adım 10, 1 resimden 1.
      • Remove the LCD 5-Point Touch Screen from the display case.
      FixBot'a Sor
      Yorum Ekle
    11. Hott T725-8G Screen/Display Replacement: adım 11, 1 resimden 1.
      • Remove the display from the plastic casing. The screen is now ready for replacement.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Emma Carroll
220 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-2, Martin Fall 2016 UMass Dartmouth, Team 6-2, Martin Fall 2016 üyesi
UMASSD-MARTIN-F16S6G2
3 Üyeler
23 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 26
Her zaman: 577
