Ana içeriğe geç
Hover-1 Charger Battery Replacement
Neye ihtiyacın var
  1. Hover-1 Charger Battery Replacement, Battery: adım 1, 2 resimden 1. Hover-1 Charger Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the hoverboard over so that the warning label is facing up.
    • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
    • Remove the four 10 mm screws with a Phillips #2 screwdriver.
    • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Hover-1 Charger Battery Replacement: adım 2, 1 resimden 1.
    • Pull the right cover away from the hoverboard to expose the battery.
    FixBot'a Sor
    Yorum Ekle
  3. Hover-1 Charger Battery Replacement: adım 3, 2 resimden 1. Hover-1 Charger Battery Replacement: adım 3, 2 resimden 2.
    • Unplug the battery by disconnecting the two pronged black and yellow cable.
    FixBot'a Sor
    Yorum Ekle
  4. Hover-1 Charger Battery Replacement: adım 4, 1 resimden 1.
    • Pull the left cover away from the hoverboard.
    FixBot'a Sor
    Yorum Ekle
  5. Hover-1 Charger Battery Replacement: adım 5, 2 resimden 1. Hover-1 Charger Battery Replacement: adım 5, 2 resimden 2.
    • Disconnect the two pronged black and yellow cable.
    • Thread the cable through the middle cylinder of the hoverboard.
    FixBot'a Sor
    Yorum Ekle
  6. Hover-1 Charger Battery Replacement: adım 6, 2 resimden 1. Hover-1 Charger Battery Replacement: adım 6, 2 resimden 2.
    • Unscrew the four 10mm screws that are holding the battery casing in place. Use a Phillips #2 screwdriver.
    • If there is a zip-tie connecting the wires together, carefully cut it with a wire cutters.
    FixBot'a Sor
    Yorum Ekle
  7. Hover-1 Charger Battery Replacement: adım 7, 3 resimden 1. Hover-1 Charger Battery Replacement: adım 7, 3 resimden 2. Hover-1 Charger Battery Replacement: adım 7, 3 resimden 3.
    • On the battery side, unplug the white five pin connector on the circuitboard.
    • Unplug the black, yellow, green and red connector on the circuitboard.
    FixBot'a Sor
    Yorum Ekle
  8. Hover-1 Charger Battery Replacement: adım 8, 1 resimden 1.
    • Move all the loose cables to the side. Pull the battery casing away from the battery.
    FixBot'a Sor
    Yorum Ekle
  9. Hover-1 Charger Battery Replacement: adım 9, 1 resimden 1.
    • Use the opening tool to remove the battery from the metal casing.
    • The battery is stuck to the metal casing with strong adhesive; do not be afraid to apply a strong force with the opening tool.
    FixBot'a Sor
    Yorum Ekle
  10. Hover-1 Charger Battery Replacement: adım 10, 1 resimden 1.
    • Remove the battery.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Melanie Hardell
517 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S12-G1, Regan Fall 2019 Cal Poly, Team S12-G1, Regan Fall 2019 üyesi
CPSU-REGAN-F19S12G1
4 Üyeler
6 adet Kılavuz yazıldı
1Rehber Yorum
Can I replace my battery 25.2v to a 36v.
Airie Green - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 24
Son 30 gün: 84
Her zaman: 10,482
