Ana içeriğe geç
Hover-1 Charger Bluetooth Speaker Replacement
Neye ihtiyacın var
  1. Hover-1 Charger Bluetooth Speaker Replacement, Unplugging the Battery: adım 1, 2 resimden 1. Hover-1 Charger Bluetooth Speaker Replacement, Unplugging the Battery: adım 1, 2 resimden 2.
    • Flip the hoverboard over so that the warning label is facing up.
    • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
    • Remove the four 10 mm screws with a Phillips #2 screwdriver.
    • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
  2. Hover-1 Charger Bluetooth Speaker Replacement: adım 2, 1 resimden 1.
    • Pull the right cover away from the hoverboard to expose the battery.
  3. Hover-1 Charger Bluetooth Speaker Replacement: adım 3, 2 resimden 1. Hover-1 Charger Bluetooth Speaker Replacement: adım 3, 2 resimden 2.
    • Disconnect the two pronged black and yellow cable.
  4. Hover-1 Charger Bluetooth Speaker Replacement: adım 4, 1 resimden 1.
    • Pull the left cover away from the hoverboard.
  5. Hover-1 Charger Bluetooth Speaker Replacement: adım 5, 2 resimden 1. Hover-1 Charger Bluetooth Speaker Replacement: adım 5, 2 resimden 2.
    • Disconnect the two pronged black and yellow cable. The battery is now fully disconnected.
  6. Hover-1 Charger Bluetooth Speaker Replacement, Bluetooth Speaker: adım 6, 1 resimden 1.
    • Locate the speaker attached to the left cover of the hoverboard.
  7. Hover-1 Charger Bluetooth Speaker Replacement: adım 7, 2 resimden 1. Hover-1 Charger Bluetooth Speaker Replacement: adım 7, 2 resimden 2.
    • Unplug the red and white four pin connector from the circuit board. Unplugging this connector is photographed as an example.
    • Unplug the white and blue three pin connector from the circuit board.
    • Unplug the white and blue two pin connector from the circuit board.
  8. Hover-1 Charger Bluetooth Speaker Replacement: adım 8, 2 resimden 1. Hover-1 Charger Bluetooth Speaker Replacement: adım 8, 2 resimden 2.
    • Using a Phillips #1 screwdriver, remove the two 7 mm screws from the circuit board.
  9. Hover-1 Charger Bluetooth Speaker Replacement: adım 9, 2 resimden 1. Hover-1 Charger Bluetooth Speaker Replacement: adım 9, 2 resimden 2.
    • Using a Phillips #1 screwdriver, remove the three screws securing the speaker to the outer shell.
  10. Hover-1 Charger Bluetooth Speaker Replacement: adım 10, 1 resimden 1.
    • Remove the speaker and circuit board from the outer shell.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bryson Shishido
145 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S12-G1, Regan Fall 2019 Cal Poly, Team S12-G1, Regan Fall 2019 üyesi
CPSU-REGAN-F19S12G1
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 15
Her zaman: 1,285
