Ana içeriğe geç
Hover-1 Charger Gyroscope Sensor Board Replacement
Neye ihtiyacın var
  1. Hover-1 Charger Gyroscope Sensor Board Replacement, Unplugging the Battery: adım 1, 2 resimden 1. Hover-1 Charger Gyroscope Sensor Board Replacement, Unplugging the Battery: adım 1, 2 resimden 2.
    • Flip the hoverboard over so that the warning label is facing up.
    • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
    • Remove the four 10 mm screws with a Phillips #2 screwdriver.
    • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Hover-1 Charger Gyroscope Sensor Board Replacement: adım 2, 1 resimden 1.
    • Pull the right cover away from the hoverboard to expose the battery.
    FixBot'a Sor
    Yorum Ekle
  3. Hover-1 Charger Gyroscope Sensor Board Replacement: adım 3, 2 resimden 1. Hover-1 Charger Gyroscope Sensor Board Replacement: adım 3, 2 resimden 2.
    • Disconnect the two pronged black and yellow cable.
    FixBot'a Sor
    Yorum Ekle
  4. Hover-1 Charger Gyroscope Sensor Board Replacement: adım 4, 1 resimden 1.
    • Pull the left cover away from the hoverboard.
    FixBot'a Sor
    Yorum Ekle
  5. Hover-1 Charger Gyroscope Sensor Board Replacement: adım 5, 2 resimden 1. Hover-1 Charger Gyroscope Sensor Board Replacement: adım 5, 2 resimden 2.
    • Disconnect the two pronged black and yellow cable. The battery is now fully disconnected.
    FixBot'a Sor
    Yorum Ekle
  6. Hover-1 Charger Gyroscope Sensor Board Replacement, Gyroscope Sensor Board: adım 6, 3 resimden 1. Hover-1 Charger Gyroscope Sensor Board Replacement, Gyroscope Sensor Board: adım 6, 3 resimden 2. Hover-1 Charger Gyroscope Sensor Board Replacement, Gyroscope Sensor Board: adım 6, 3 resimden 3.
    • Unplug the white five pin connector from the gyroscope sensor board.
    • Unplug the red, yellow, blue, green, black and white six pin connector.
    • Unplug the black and red two pin connector.
    • Unplug the black, yellow, green and red four pin connector. Unplugging this connector is photographed as an example.
    FixBot'a Sor
    Yorum Ekle
  7. Hover-1 Charger Gyroscope Sensor Board Replacement: adım 7, 2 resimden 1. Hover-1 Charger Gyroscope Sensor Board Replacement: adım 7, 2 resimden 2.
    • Remove the four 10 mm screws from the gyroscope sensor board with a Phillips #2 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  8. Hover-1 Charger Gyroscope Sensor Board Replacement: adım 8, 3 resimden 1. Hover-1 Charger Gyroscope Sensor Board Replacement: adım 8, 3 resimden 2. Hover-1 Charger Gyroscope Sensor Board Replacement: adım 8, 3 resimden 3.
    • Push the rubber sheaths away from the clasp of the green bullet connector.
    • Grasp the connector at the metal junction and disconnect.
    • Repeat for the yellow and red bullet connectors.
    • There may be a zip tie holding these wires together. Cut this off.
    • These bullet connectors may be hard to disconnect; do not be afraid to pull with strong force.
    FixBot'a Sor
    Yorum Ekle
  9. Hover-1 Charger Gyroscope Sensor Board Replacement: adım 9, 1 resimden 1.
    • Remove the gyroscope sensor board.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Melanie Hardell
517 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S12-G1, Regan Fall 2019 Cal Poly, Team S12-G1, Regan Fall 2019 üyesi
CPSU-REGAN-F19S12G1
4 Üyeler
6 adet Kılavuz yazıldı
5Kılavuz Yorumları
Hi Where can I find the replacement sensor board? Thanks!
Jason LaDuke - Yanıt Paylaş
where do i find the replacement sensor board?
one wheel of my board doesn’t work
Philip Donkoh - Yanıt Paylaş
I need one of these replacement gyros please how I get
Matthew Isaiah Cowart - Yanıt Paylaş
Worthless guide. No instructions on where to get the replacement gyro boards
Fuckaboi - Yanıt Paylaş
this is a joke. 2 years still not one kind enough soul to help find where to purchase replacements!!!!!!!!
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 52
Her zaman: 6,077
