Ana içeriğe geç
Hover-1 Charger LED Headlight Replacement
Neye ihtiyacın var
  1. Hover-1 Charger LED Headlight Replacement, Unplugging the Battery: adım 1, 2 resimden 1. Hover-1 Charger LED Headlight Replacement, Unplugging the Battery: adım 1, 2 resimden 2.
    • Flip the hoverboard over so that the warning label is facing up.
    • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
    • Remove the four 10 mm screws with a Phillips #2 screwdriver.
    • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
  2. Hover-1 Charger LED Headlight Replacement: adım 2, 1 resimden 1.
    • Pull the right cover away from the hoverboard to expose the battery.
  3. Hover-1 Charger LED Headlight Replacement: adım 3, 2 resimden 1. Hover-1 Charger LED Headlight Replacement: adım 3, 2 resimden 2.
    • Disconnect the two pronged black and yellow cable.
  4. Hover-1 Charger LED Headlight Replacement: adım 4, 1 resimden 1.
    • Pull the left cover away from the hoverboard.
  5. Hover-1 Charger LED Headlight Replacement: adım 5, 2 resimden 1. Hover-1 Charger LED Headlight Replacement: adım 5, 2 resimden 2.
    • Disconnect the two pronged black and yellow cable. The battery is now fully disconnected.
  6. Hover-1 Charger LED Headlight Replacement, LED Headlight: adım 6, 2 resimden 1. Hover-1 Charger LED Headlight Replacement, LED Headlight: adım 6, 2 resimden 2.
    • Remove the black and red two pin connector from the circuitboard.
  7. Hover-1 Charger LED Headlight Replacement: adım 7, 2 resimden 1. Hover-1 Charger LED Headlight Replacement: adım 7, 2 resimden 2.
    • Remove the two 12mm screws holding the LED to the front cover with a Phillips #2 screwdriver.
    • Our Hoverboard was missing a screw in the LED housing. Yours may or may not be missing screws as well.
  8. Hover-1 Charger LED Headlight Replacement: adım 8, 1 resimden 1.
    • With the wire unplugged and screws removed, you can now safely seperate the LED from the Hoverboard.
Sonuç
Benji Forest
266 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S12-G1, Regan Fall 2019 Cal Poly, Team S12-G1, Regan Fall 2019 üyesi
CPSU-REGAN-F19S12G1
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 201
