Giriş
If the LED headlights on your Hover-1 Charger (H1-COL) are not turning on, you may have to replace them. Before you begin disassembling your hoverboard, check out our troubleshooting page that addresses LED headlights. If the problem persists, this guide will help you replace your hoverboard’s right LED headlight. Removal of the left headlight will follow very similar steps.
Make sure to wear an anti-static wrist strap to protect the electronics against buildup of static electricity. Some screw housings are fragile; they may fall apart when the screw is removed.
Neye ihtiyacın var
Flip the hoverboard over so that the warning label is facing up.
Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
Remove the four 10 mm screws with a Phillips #2 screwdriver.
