Ana içeriğe geç
Hover-1 Eagle Back Wheel Replacement
Neye ihtiyacın var
  1. Hover-1 Eagle Back Wheel Replacement, Back Wheel: adım 1, 1 resimden 1.
    • Peel off the reflective red axle sticker using a plastic spudger.
    FixBot'a Sor
    Yorum Ekle
  2. Hover-1 Eagle Back Wheel Replacement: adım 2, 1 resimden 1.
    • Use a Phillips #2 screwdriver to remove the 2mm screw located underneath the reflective sticker.
    FixBot'a Sor
    Yorum Ekle
  3. Hover-1 Eagle Back Wheel Replacement: adım 3, 3 resimden 1. Hover-1 Eagle Back Wheel Replacement: adım 3, 3 resimden 2. Hover-1 Eagle Back Wheel Replacement: adım 3, 3 resimden 3.
    • Grip the deck flare and slide it towards the tail end of the scooter.
    FixBot'a Sor
    Yorum Ekle
  4. Hover-1 Eagle Back Wheel Replacement: adım 4, 1 resimden 1.
    • Remove the 6 mm axle screws by using a hex bit 5.0.
    • Make sure to try loosening both sides. One of the axle screws spins freely and will not loosen.
    FixBot'a Sor
    Yorum Ekle
  5. Hover-1 Eagle Back Wheel Replacement: adım 5, 3 resimden 1. Hover-1 Eagle Back Wheel Replacement: adım 5, 3 resimden 2. Hover-1 Eagle Back Wheel Replacement: adım 5, 3 resimden 3.
    • Repeat Steps 1-3 for the other side.
    • Apply pressure to the axle using a hex bit 5.0 to push it slightly out on the other side.
    • Take hold of the 6 mm axle screw on the opposite side and remove the axle by pulling firmly towards you.
    FixBot'a Sor
    Yorum Ekle
  6. Hover-1 Eagle Back Wheel Replacement: adım 6, 2 resimden 1. Hover-1 Eagle Back Wheel Replacement: adım 6, 2 resimden 2.
    • Pull backwards to remove the back wheel.
    • Washers may fall when the wheel is removed, so make sure to catch or gather the washers.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, repeat Steps 1-4 in reverse order.
5 farklı kişi bu kılavuzu tamamladı.
Andrew Gaskell
1.137 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G2, White Winter 2020 Cal Poly, Team S1-G2, White Winter 2020 üyesi
CPSU-WHITE-W20S1G2
4 Üyeler
6 adet Kılavuz yazıldı
1Rehber Yorum
Where do you buy the wheels
Thanks
antonio flores - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 22
Son 30 gün: 101
Her zaman: 4,252
