Ana içeriğe geç
Hover-1 Eagle LED Headlight Replacement
Neye ihtiyacın var
  1. Hover-1 Eagle LED Headlight Replacement, LED Headlight: adım 1, 3 resimden 1. Hover-1 Eagle LED Headlight Replacement, LED Headlight: adım 1, 3 resimden 2. Hover-1 Eagle LED Headlight Replacement, LED Headlight: adım 1, 3 resimden 3.
    • Remove the four screws from the bottom side of the display housing using a Phillips #2 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Hover-1 Eagle LED Headlight Replacement: adım 2, 3 resimden 1. Hover-1 Eagle LED Headlight Replacement: adım 2, 3 resimden 2. Hover-1 Eagle LED Headlight Replacement: adım 2, 3 resimden 3.
    • Carefully remove the top of the housing containing the display screen.
    • Remove the top of the housing slowly to avoid damaging the wires.
    FixBot'a Sor
    Yorum Ekle
  3. Hover-1 Eagle LED Headlight Replacement: adım 3, 2 resimden 1. Hover-1 Eagle LED Headlight Replacement: adım 3, 2 resimden 2.
    • Slide the LED light cover upwards out of the display housing
    • Be gentle when removing the LED light cover to avoid damaging the LED's connecting wires.
    • The LED circuit board should slide out with the LED light cover.
    • To reassemble, align the prongs of the LED cover with the holes in the LED circuit board.
    FixBot'a Sor
    Yorum Ekle
  4. Hover-1 Eagle LED Headlight Replacement: adım 4, 3 resimden 1. Hover-1 Eagle LED Headlight Replacement: adım 4, 3 resimden 2. Hover-1 Eagle LED Headlight Replacement: adım 4, 3 resimden 3.
    • Using a soldering iron, desolder the black and red wires from the LED circuit board.
    • To reassemble, solder the same black and red wires onto the new LED circuit board.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Andrew Gaskell
1.137 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G2, White Winter 2020 Cal Poly, Team S1-G2, White Winter 2020 üyesi
CPSU-WHITE-W20S1G2
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 11
Son 30 gün: 27
Her zaman: 1,647
