Ana içeriğe geç
Hover-1 Eagle Throttle/Brake Lever Replacement
Neye ihtiyacın var
  1. Hover-1 Eagle Throttle/Brake Lever Replacement, Throttle/Brake Lever: adım 1, 3 resimden 1. Hover-1 Eagle Throttle/Brake Lever Replacement, Throttle/Brake Lever: adım 1, 3 resimden 2. Hover-1 Eagle Throttle/Brake Lever Replacement, Throttle/Brake Lever: adım 1, 3 resimden 3.
    • Unscrew the scooter handle.
    • The scooter handles are left-handed or reverse threaded, so twist clockwise to remove them.
  2. Hover-1 Eagle Throttle/Brake Lever Replacement: adım 2, 3 resimden 1. Hover-1 Eagle Throttle/Brake Lever Replacement: adım 2, 3 resimden 2. Hover-1 Eagle Throttle/Brake Lever Replacement: adım 2, 3 resimden 3.
    • Push back the fastening clips by wedging the plastic spudger between the clip and the throttle handle.
    • Insert iFixit opening picks between each fastening clip and the throttle handle to prevent re-fastening.
    • Pull the throttle lever off gently by pulling towards you.
    • The spring housed in the handle can sometimes send the lever flying. Maintain a firm grip on the throttle lever.
  3. Hover-1 Eagle Throttle/Brake Lever Replacement: adım 3, 3 resimden 1. Hover-1 Eagle Throttle/Brake Lever Replacement: adım 3, 3 resimden 2. Hover-1 Eagle Throttle/Brake Lever Replacement: adım 3, 3 resimden 3.
    • To reassemble, insert the spring into the placement hole, housed inside the throttle handle. Insert the other end of the spring into the placement hole inside the throttle body housing.
  4. Hover-1 Eagle Throttle/Brake Lever Replacement: adım 4, 3 resimden 1. Hover-1 Eagle Throttle/Brake Lever Replacement: adım 4, 3 resimden 2. Hover-1 Eagle Throttle/Brake Lever Replacement: adım 4, 3 resimden 3.
    • Twist the throttle lever back to its original orientation by rotating it to the left.
    • Apply pressure to the throttle handle until you hear the fastening clips take hold the of the throttle lever.
    • Make sure the throttle lever is fully inserted and flush with the display throttle body.
  5. Hover-1 Eagle Throttle/Brake Lever Replacement: adım 5, 3 resimden 1. Hover-1 Eagle Throttle/Brake Lever Replacement: adım 5, 3 resimden 2. Hover-1 Eagle Throttle/Brake Lever Replacement: adım 5, 3 resimden 3.
    • Reattach the scooter handle.
    • Make sure to twist the handles counterclockwise to tighten.
Bitiş Çizgisi
4 farklı kişi bu kılavuzu tamamladı.
Andrew Gaskell
1.008 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G2, White Winter 2020 Cal Poly, Team S1-G2, White Winter 2020 üyesi
CPSU-WHITE-W20S1G2
4 Üyeler
6 adet Kılavuz yazıldı
24 Yorum
Great detail……….. Where can I buy the replacement part (throttle) the company hover1 isn't answering me and they don't have this part on their website. Thanks
hanjna76 - Yanıt
Im needed a throttle did anyone have any luck?
rodarte_amanda1992 -
Where do I buy the part where do I get it please let me know The brake lever
poorbubbaa - Yanıt
Necesito acelerador y no lo encuentro.
Josue Villanueva - Yanıt
I cant squeeze the spudger and the pick between this and the spudger broke…what the!!!
Cheri Rael - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 29
Son 30 gün: 86
Her zaman: 15,464
