Ana içeriğe geç
Hover-1 Folding E-Scooter LED Headlight Replacement
Neye ihtiyacın var
  1. Hover-1 Folding E-Scooter LED Headlight Replacement, LED Headlight: adım 1, 2 resimden 1. Hover-1 Folding E-Scooter LED Headlight Replacement, LED Headlight: adım 1, 2 resimden 2.
    • Face the front of the scooter towards you.
    • Remove all four 24mm bolts by turning counterclockwise using the Hex 4 screwdriver bit.
  2. Hover-1 Folding E-Scooter LED Headlight Replacement: adım 2, 2 resimden 1. Hover-1 Folding E-Scooter LED Headlight Replacement: adım 2, 2 resimden 2.
    • Remove the headlight housing.
    • The LED should release when you take off the cover.
    • Be careful when taking off the cover; the light is glued onto the cover and could harm the device.
  3. Hover-1 Folding E-Scooter LED Headlight Replacement: adım 3, 2 resimden 1. Hover-1 Folding E-Scooter LED Headlight Replacement: adım 3, 2 resimden 2.
    • Disconnect the red wire using a soldering iron.
    • The soldering iron should melt the glue for you, so don't worry about removing it yourself.
  4. Hover-1 Folding E-Scooter LED Headlight Replacement: adım 4, 1 resimden 1.
    • For ease of installation, tin your new LED and the connecting wire with the soldering iron and solder.
    • Solder your new light on to the existing red wire.
    • For help on how to solder, refer to iFixit's Soldering Guide.
Sonuç
To reassemble your device, follow these instructions in reverse order with the new LED.
Nicolo DiFronzo
229 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S15-G5, White Fall 2018 Cal Poly, Team S15-G5, White Fall 2018 üyesi
CPSU-WHITE-F18S15G5
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 21
Her zaman: 3,212
