Ana içeriğe geç
Hover-1 Folding E-Scooter Rear Wheel Replacement
Neye ihtiyacın var
  1. Hover-1 Folding E-Scooter Rear Wheel Replacement, Rear Wheel: adım 1, 2 resimden 1. Hover-1 Folding E-Scooter Rear Wheel Replacement, Rear Wheel: adım 1, 2 resimden 2.
    • Remove either of the two 0.2 mm axle screws by using a hex bit 4.0 by turning clockwise.
    • The two screws are the same thread so find the screw that has the least torque. Only that screw will be able to removed in this step.
    • Turn the hex bit 4.0 counterclockwise to reassemble the axle screws.
  2. Hover-1 Folding E-Scooter Rear Wheel Replacement: adım 2, 3 resimden 1. Hover-1 Folding E-Scooter Rear Wheel Replacement: adım 2, 3 resimden 2. Hover-1 Folding E-Scooter Rear Wheel Replacement: adım 2, 3 resimden 3.
    • Slide off the plastic side panel.
    What is the Pat number of this plastic side panel?
    bobdub - Yanıt
  3. Hover-1 Folding E-Scooter Rear Wheel Replacement: adım 3, 1 resimden 1.
    • Use a hex bit 4.0 to screw back in the 0.2 mm screw as tightly as possible by turning clockwise.
    • You will need to hold the other screw you are not replacing with an additional hex bit 4.0, so that the screws don't spin freely.
  4. Hover-1 Folding E-Scooter Rear Wheel Replacement: adım 4, 1 resimden 1.
    • Flip over the scooter and use the hex bit 4.0 to remove the other 0.2 mm screw.
  5. Hover-1 Folding E-Scooter Rear Wheel Replacement: adım 5, 3 resimden 1. Hover-1 Folding E-Scooter Rear Wheel Replacement: adım 5, 3 resimden 2. Hover-1 Folding E-Scooter Rear Wheel Replacement: adım 5, 3 resimden 3.
    • Slide off the other plastic side panel.
  6. Hover-1 Folding E-Scooter Rear Wheel Replacement: adım 6, 1 resimden 1.
    • On the same side you removed the screw, use the bit extender to push down on the axle inside the wheel.
    • The axle pops out and the wheel easily comes off.
    • Two washers will pop out with the axle.
Sonuç
Luke Imai
133 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S15-G5, White Fall 2018 Cal Poly, Team S15-G5, White Fall 2018 üyesi
CPSU-WHITE-F18S15G5
4 Üyeler
5 adet Kılavuz yazıldı
2Kılavuz Yorumları
Where can you get replacement rubber for the front and rear wheels?
jackricotta - Yanıt
How about adding a rear wheel removal article for the Hover-1 Alpha folding scooter?
sfaheysd - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 49
Her zaman: 5,601
