Ana içeriğe geç
Hover-1 XLS Ignition Replacement
Neye ihtiyacın var
  1. Hover-1 XLS Ignition Replacement, Ignition: adım 1, 1 resimden 1.
    • Remove the six 16mm #3 Hex head screws located on the front panel.
    • The screws are held in with Teflon tape, so use a chemical remover like B'laster to loosen the screws.
    FixBot'a Sor
    Yorum Ekle
  2. Hover-1 XLS Ignition Replacement: adım 2, 3 resimden 1. Hover-1 XLS Ignition Replacement: adım 2, 3 resimden 2. Hover-1 XLS Ignition Replacement: adım 2, 3 resimden 3.
    • Grab the front panel and gently lift it up to the side.
    • The front panel is connected to the ignition, so don't pull too hard or the wires will get damaged.
    FixBot'a Sor
    Yorum Ekle
  3. Hover-1 XLS Ignition Replacement: adım 3, 1 resimden 1.
    • Remove the two, 19 mm Phillips #2 screws holding the ignition.
    • Remove the yellow and red wires that are connected to the ignition. To remove them, look at the soldering guide provided by iFixit.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Jonathan Hidalgo
659 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G2, White Winter 2019 Cal Poly, Team S1-G2, White Winter 2019 üyesi
CPSU-WHITE-W19S1G2
3 Üyeler
13 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 14
Son 30 gün: 46
Her zaman: 1,637
