Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Slide the SSD sled out of the metal enclosure to remove it.
Carefully insert your Mac OEM SSD as shown, with the golden contact pads below the connector pins facing upward.
Use a Phillips driver to install the 4.5 mm screw securing the bottom of the SSD.
Slide the SSD sled into the metal enclosure, SSD connector end first.
Place the port cover plate onto the end of the enclosure, aligning the USB-C port with its cutout.
Use a Phillips driver to install the two 8 mm screws onto the end of the enclosure.
The drive is now ready to be connected to your computer with either of the included USB cables.
8 farklı kişi bu kılavuzu tamamladı.
4 Yorum
Danke für das Teilen. Es wäre besser, wenn Sie ein zusätzliches Video-Tutorial haben. bloxorz
Is there any driver that needs installed for this? My MacBook Pro, a MacBook Air, and a Windows machine do not recognize any USB storage device is being connected at all. Nothing shows up with Disk Utility.
Installed an original MacBook Air 11" Early 2014 SSD drive - doesn't work at all! Waisted €119,95
