Ana içeriğe geç
How To Repair a Faulty Switch on a Trio-60 Keyboard
Neye ihtiyacın var
  1. How To Repair a Faulty Switch on a  Trio-60 Keyboard, Key Switch: adım 1, 2 resimden 1. How To Repair a Faulty Switch on a  Trio-60 Keyboard, Key Switch: adım 1, 2 resimden 2.
    • Unplug the keyboard
  2. How To Repair a Faulty Switch on a  Trio-60 Keyboard: adım 2, 3 resimden 1. How To Repair a Faulty Switch on a  Trio-60 Keyboard: adım 2, 3 resimden 2. How To Repair a Faulty Switch on a  Trio-60 Keyboard: adım 2, 3 resimden 3.
    • Use a keycap puller to remove the keycaps "3", "4", "0'", "-", "Caps Lock", "enter" and both "alt" keys to gain access to screws.
    • Place the keycap puller straight over the keycap, so that the wires are under the keycap and pull straight up.
    • It may require slight angling and pressure to remove the keycap.
  3. How To Repair a Faulty Switch on a  Trio-60 Keyboard: adım 3, 3 resimden 1. How To Repair a Faulty Switch on a  Trio-60 Keyboard: adım 3, 3 resimden 2. How To Repair a Faulty Switch on a  Trio-60 Keyboard: adım 3, 3 resimden 3.
    • Remove six 4.0 mm screws with a Phillips #0 screwdriver.
    • Consider using a magnetized screwdriver or magnet to remove screws, or leave them in the chassis.
  4. How To Repair a Faulty Switch on a  Trio-60 Keyboard: adım 4, 2 resimden 1. How To Repair a Faulty Switch on a  Trio-60 Keyboard: adım 4, 2 resimden 2.
    • Remove the top chassis (metal cover) by lifting straight up and off of the keyboard.
  5. How To Repair a Faulty Switch on a  Trio-60 Keyboard: adım 5, 3 resimden 1. How To Repair a Faulty Switch on a  Trio-60 Keyboard: adım 5, 3 resimden 2. How To Repair a Faulty Switch on a  Trio-60 Keyboard: adım 5, 3 resimden 3.
    • Gently flip the plate and PCB towards the back of the case, so that it lies upside down behind the case.
    • Ensure not to pull on or twist the keyboard as it's attached to a cable and could cause damage.
  6. How To Repair a Faulty Switch on a  Trio-60 Keyboard: adım 6, 2 resimden 1. How To Repair a Faulty Switch on a  Trio-60 Keyboard: adım 6, 2 resimden 2.
    • Use your fingers or a spudger to remove the JST cable on the end of the circuit board.
  7. How To Repair a Faulty Switch on a  Trio-60 Keyboard: adım 7, 2 resimden 1. How To Repair a Faulty Switch on a  Trio-60 Keyboard: adım 7, 2 resimden 2.
    • Make sure to desolder in a well-ventilated area, as the smoke released from the boiling flux is toxic. Placing a small fan near and facing away from your soldering area is recommended.
    • Heat the solder until it appears liquified.
    • Use your preferred sucking tool of choice to remove the solder (an electric desolder is recommended).
    • Desolder both points for each switch you are removing.
    • The location of desoldering may vary depending on which switches are faulty.
  8. How To Repair a Faulty Switch on a  Trio-60 Keyboard: adım 8, 2 resimden 1. How To Repair a Faulty Switch on a  Trio-60 Keyboard: adım 8, 2 resimden 2.
    • Use a switch puller or your fingers to remove the faulty switch.
  9. How To Repair a Faulty Switch on a  Trio-60 Keyboard: adım 9, 3 resimden 1. How To Repair a Faulty Switch on a  Trio-60 Keyboard: adım 9, 3 resimden 2. How To Repair a Faulty Switch on a  Trio-60 Keyboard: adım 9, 3 resimden 3.
    • If a pin is bent, flatten it with pliers so that it is perpendicular to the switch.
    • If the pin is not bent, there may be electronic issues causing switch malfunction that will not be covered in this guide.
  10. How To Repair a Faulty Switch on a  Trio-60 Keyboard: adım 10, 2 resimden 1. How To Repair a Faulty Switch on a  Trio-60 Keyboard: adım 10, 2 resimden 2.
    • Place the new or repaired switch straight down until it is firmly locked into plate.
  11. How To Repair a Faulty Switch on a  Trio-60 Keyboard: adım 11, 1 resimden 1.
    • Solder the switch and test the keyboard to ensure it functions correctly.
    • Make sure to solder in a well-ventilated area, as the smoke released from the boiling flux is toxic. Placing a small fan near and facing away from your soldering area is recommended.
  12. How To Repair a Faulty Switch on a  Trio-60 Keyboard: adım 12, 2 resimden 1. How To Repair a Faulty Switch on a  Trio-60 Keyboard: adım 12, 2 resimden 2.
    • Optionally apply isopropyl alcohol to Q-tip and clean flux residue from solder joints.
Sonuç
Chase Keighley
205 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 1-3, Morris Spring 2023 UC Davis, Team 1-3, Morris Spring 2023 üyesi
UCD-MORRIS-S23S1G3
3 Üyeler
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 24
Her zaman: 212
