Ana içeriğe geç
How To Replace Ski Pole Baskets
Lia Garkie
Lia Garkie ve 5 diğer katkıda bulunanlar
En son August 10, 2023 tarihinde güncellendi
30 - 45 dakika
Orta
Have you ever broken or cracked the baskets on your skis? Use this guide to replace your worn baskets and return your skis to excellent working condition!
  1. How To Replace Ski Pole Baskets, How To Replace Ski Pole Baskets: adım 1, 2 resimden 1. How To Replace Ski Pole Baskets, How To Replace Ski Pole Baskets: adım 1, 2 resimden 2.
    • Place the sock over your hand like a glove.
    • You will be using this hand to pull off the heated basket.
  2. How To Replace Ski Pole Baskets: adım 2, 2 resimden 1. How To Replace Ski Pole Baskets: adım 2, 2 resimden 2.
    • Heat the worn/broken basket with a blow dryer to melt the existing adhesive.
    • Heat for no longer then three minutes.
  3. How To Replace Ski Pole Baskets: adım 3, 2 resimden 1. How To Replace Ski Pole Baskets: adım 3, 2 resimden 2.
    • Use your protected hand to pull firmly on the basket until it comes off of the pole once it is heated.
  4. How To Replace Ski Pole Baskets: adım 4, 2 resimden 1. How To Replace Ski Pole Baskets: adım 4, 2 resimden 2.
    • Heat an all purpose glue stick with a lighter.
  5. How To Replace Ski Pole Baskets: adım 5, 2 resimden 1. How To Replace Ski Pole Baskets: adım 5, 2 resimden 2.
    • Spread a very thin layer of the melted glue on the basket end of the pole, then press on the new basket.
    • Press the new basket immediately after applying the melted glue in order to obtain maximum adhesion.
  6. How To Replace Ski Pole Baskets: adım 6, 1 resimden 1.
    • Reheat the replaced basket with a hair dryer for a minute.
    • After heating, allow the glue to cool and set for 10 minutes.
  7. How To Replace Ski Pole Baskets: adım 7, 1 resimden 1.
    • After drying for 10 minutes, your poles will be ready for use. Happy Skiing!
Sonuç
Bir başkası bu kılavuzu tamamladı.
Lia Garkie
131 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 30-3, Green Spring 2015 Cal Poly, Team 30-3, Green Spring 2015 üyesi
CPSU-GREEN-S15S30G3
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 27
Son 30 gün: 72
Her zaman: 17,605
