Ana içeriğe geç
How do I replace the wheels on my Tobago trolley?
Neye ihtiyacın var
  1. How do I replace the wheels on my Tobago trolley?, Wheels: adım 1, 3 resimden 1. How do I replace the wheels on my Tobago trolley?, Wheels: adım 1, 3 resimden 2. How do I replace the wheels on my Tobago trolley?, Wheels: adım 1, 3 resimden 3.
    • Open the trolley and unzip the lining.
  2. How do I replace the wheels on my Tobago trolley?: adım 2, 2 resimden 1. How do I replace the wheels on my Tobago trolley?: adım 2, 2 resimden 2.
    • Unscrew the 4 marked screws with a Phillips screwdriver.
    • When attaching the new wheels, take care not to over tighten the screws.
    • Use the flat-blade screwdriver to remove the 2 washers.
    • Removing the wheelhouse from the trolley.
    • Pinch off the two remaining rivets with the tongs.
  3. How do I replace the wheels on my Tobago trolley?: adım 6, 3 resimden 1. How do I replace the wheels on my Tobago trolley?: adım 6, 3 resimden 2. How do I replace the wheels on my Tobago trolley?: adım 6, 3 resimden 3.
    • Remove the other 2 rivets on the outside of the trolley using the flat-blade screwdriver. Then remove the wheelhouse from the trolley.
    • When attaching the new wheelhouse, take care not to over tighten the screws.
Sonuç
Follow the instructions in reverse order to finish the repair.
VAUDE Reparaturteam
6.279 İtibar
32 adet Kılavuz yazıldı
Ekip
Vaudesport Vaudesport üyesi
Community
3 Üyeler
96 adet Kılavuz yazıldı
3 Yorum
Dear Vaude, I have a Module 60 where the airline has managed to snap of a wheel recently. I am in contact with the UK supplier of Vaude parts, but is the repair similar to above and therefore I need to order the right hand side plastic/wheel? Thank you for any help.
JANE D - Yanıt
Dear Jane, yes, you can use this repair guide also for your Module Trolley. You will get a set of wheels, you so can change both if you want.
VAUDE Reparaturteam -
Dear Vaude
I have a trolley Samoa, and it seems I can't get replacements like for the Tobago. Any idea how I could find wheels to replace the broken ones?
Rollo Launche - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 22
Son 30 gün: 70
Her zaman: 4,921
