Ana içeriğe geç
How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes
Neye ihtiyacın var
  1. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes, How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: adım 1, 1 resimden 1.
    • You will see a cable attached to an Allen bolt.
  2. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: adım 2, 1 resimden 1.
    • Loosen up the bolt with the help of Hex key set.
  3. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: adım 3, 2 resimden 1. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: adım 3, 2 resimden 2.
    • Now, pull the cable as much as you can.
  4. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: adım 4, 1 resimden 1.
    • Tighten up the bolt while you keep pulling the cable.
  5. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: adım 5, 2 resimden 1. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: adım 5, 2 resimden 2.
    • To center the caliper for a smooth breaking experience, loosen up the two bolts of the brake situated at top and at bottom.
  6. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: adım 6, 1 resimden 1.
    • Now, put the brake on.
  7. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: adım 7, 3 resimden 1. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: adım 7, 3 resimden 2. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: adım 7, 3 resimden 3.
    • While putting the brake on, tighten up both the bolts.
    • You are finished adjusting the brakes!
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Dude, the cable is attached incorrectly. The cable routes up and over the little arm.
Grandy - Yanıt
I need a replacement t25 bolt and square ribbed nut that is shown in step 4. Any help would be stellar.
gr8fuljqr - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 23
Son 30 gün: 109
Her zaman: 5,631
