Ana içeriğe geç
How to Clean Dust Out of a Playstation 5 Without Opening It
Neye ihtiyacın var
  1. How to Clean Dust Out of a Playstation 5 Without Opening It, Remove the stand screw: adım 1, 1 resimden 1.
    • If your PlayStation 5 is in its vertical orientation, flip it upside down so the stand is facing up.
    • If your PlayStation 5 is in its horizontal orientation, skip to Step 6.
    • Work on a flat surface to prevent your PlayStation from falling over.
    • Use a coin or a flathead screwdriver to remove the 26.5 mm-long stand screw.
  2. How to Clean Dust Out of a Playstation 5 Without Opening It, Remove the vertical stand: adım 2, 2 resimden 1. How to Clean Dust Out of a Playstation 5 Without Opening It, Remove the vertical stand: adım 2, 2 resimden 2.
    • Lift straight up to remove the stand.
  3. How to Clean Dust Out of a Playstation 5 Without Opening It, Store the stand screw: adım 3, 2 resimden 1. How to Clean Dust Out of a Playstation 5 Without Opening It, Store the stand screw: adım 3, 2 resimden 2.
    • Insert the screw into the cubby on the bottom of the stand.
  4. How to Clean Dust Out of a Playstation 5 Without Opening It, Cap the screw hole: adım 4, 3 resimden 1. How to Clean Dust Out of a Playstation 5 Without Opening It, Cap the screw hole: adım 4, 3 resimden 2. How to Clean Dust Out of a Playstation 5 Without Opening It, Cap the screw hole: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers or your fingernail to remove the cap from the cubby.
    • Use your finger to press the cap into the screw hole.
  5. How to Clean Dust Out of a Playstation 5 Without Opening It, Close the cubby: adım 5, 3 resimden 1. How to Clean Dust Out of a Playstation 5 Without Opening It, Close the cubby: adım 5, 3 resimden 2. How to Clean Dust Out of a Playstation 5 Without Opening It, Close the cubby: adım 5, 3 resimden 3.
    • Twist the stand counterclockwise to close the cubby.
  6. How to Clean Dust Out of a Playstation 5 Without Opening It, Remove the horizontal stand: adım 6, 2 resimden 1. How to Clean Dust Out of a Playstation 5 Without Opening It, Remove the horizontal stand: adım 6, 2 resimden 2.
    • If your PlayStation 5 is in its horizontal orientation, rest it on its face with the charging port facing up.
    • Lift the stand straight up to remove it.
  7. How to Clean Dust Out of a Playstation 5 Without Opening It, Remove the left faceplate: adım 7, 3 resimden 1. How to Clean Dust Out of a Playstation 5 Without Opening It, Remove the left faceplate: adım 7, 3 resimden 2. How to Clean Dust Out of a Playstation 5 Without Opening It, Remove the left faceplate: adım 7, 3 resimden 3.
    • Lift up the corner of the faceplate with the PlayStation logo to unclip it from the case.
  8. How to Clean Dust Out of a Playstation 5 Without Opening It: adım 8, 2 resimden 1. How to Clean Dust Out of a Playstation 5 Without Opening It: adım 8, 2 resimden 2.
    • While lifting up the corner, slide the faceplate towards the bottom of the device.
    • Remove the left faceplate.
  9. How to Clean Dust Out of a Playstation 5 Without Opening It, Vacuum out the dust: adım 9, 3 resimden 1. How to Clean Dust Out of a Playstation 5 Without Opening It, Vacuum out the dust: adım 9, 3 resimden 2. How to Clean Dust Out of a Playstation 5 Without Opening It, Vacuum out the dust: adım 9, 3 resimden 3.
    • Use a vacuum to clean out the two dust catchers.
    • A narrow vacuum attachment would be best.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our PlayStation 5 Answers community for help.
50 farklı kişi bu kılavuzu tamamladı.
Robert Boyd
31.586 İtibar
94 adet Kılavuz yazıldı
2Kılavuz Yorumları
Tank you. Good
askr chamani - Yanıt
muchas gracias!!! muy facil acabo de hacerle una limpieza a mi consola
J4s3ph - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 90
Son 7 gün: 680
Son 30 gün: 2,947
Her zaman: 195,594
