Ana içeriğe geç
How to Clear a blocked, or clogged sink
  1. How to Clear a blocked, or clogged sink, How to Clear a blocked, or clogged sink: adım 1, 1 resimden 1.
    • When you first go to clear your sink, you should check how the pipes are connected.
  2. How to Clear a blocked, or clogged sink: adım 2, 1 resimden 1.
    • If your piping looks like the photo, you won't need tools to make this fix.
    • You can easily remove these pipes by twisting them off at the brackets.
  3. How to Clear a blocked, or clogged sink: adım 3, 2 resimden 1. How to Clear a blocked, or clogged sink: adım 3, 2 resimden 2.
    • Twist the higher bracket until it comes undone.
    If you don’t have the leverage tabs or the slip nut just seems stuck, wrapping a rag around it can help you torque on it (counterclockwise from top) without hurting your hands so much. Using a damp rag can help it not slip over itself and the plastic. A rubber jar opener also works.
    Stephen Frost - Yanıt
  4. How to Clear a blocked, or clogged sink: adım 4, 1 resimden 1.
    • Twist the lower bracket until it also comes undone.
    • Water and other liquids will pour out of the brackets so hold the pipe tightly to avoid making a mess.
  5. How to Clear a blocked, or clogged sink: adım 5, 1 resimden 1.
    • Gently remove the pipe and find somewhere to dump out the contents that caused it to be clogged.
    • The pipe will be full of water and whatever is stuck inside. Any large obstructions or other blockages may fall out.
  6. How to Clear a blocked, or clogged sink: adım 6, 1 resimden 1.
    • Clear out the gunk, obstructions, and any other objects in the pipe so that your sink drains properly.
  7. How to Clear a blocked, or clogged sink: adım 7, 1 resimden 1.
    • Repeat the steps in reverse to put it back together again.
    • The blockage should now be removed and the sink should be draining properly.
    Captain Obvious says: Hand tighten the nuts enough so the wedge fitting or washer compresses enough to not leak. The wedge action is what does it. (Put the wedge washer in the right way so the flat part is against the nut and the sharper angle fits in the pipe bevel.)
Sonuç
Your sink should now be free of obstructions or clogs in the pipes.
4 farklı kişi bu kılavuzu tamamladı.
Elijah Santiago
196 İtibar
1 Kılavuz yazıldı
Ekip
1Rehber Yorum
Smalll repairs can be done on a diy basis, but if drain clogging a regular problem the best solution would be to turn to professional pipe cleaning and restoration. i.e. pipe rehabilitation.
Kanserwis Sp. z o.o - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 15
Son 30 gün: 33
Her zaman: 2,144
