Ana içeriğe geç
How to Detach the Keyboard on a Surface Book
Neye ihtiyacın var
  1. How to Detach the Keyboard on a Surface Book, Remove the display with the Detach button: adım 1, 3 resimden 1. How to Detach the Keyboard on a Surface Book, Remove the display with the Detach button: adım 1, 3 resimden 2. How to Detach the Keyboard on a Surface Book, Remove the display with the Detach button: adım 1, 3 resimden 3.
    • In order for the keyboard to be detached with the Detach buttons, both batteries must be charged above 10 percent. If your device doesn't power on and you can't use the Detach buttons, skip to the next step.
    • Press and hold the Detach button on the keyboard.
    • Once pressed, the Detach button it will light up red. After a second, it’ll turn green and you’ll hear an audible clicking sound.
    • Alternatively, click the Detach icon on the right-hand side of the Windows 10 taskbar.
    • Remove the display.
  2. How to Detach the Keyboard on a Surface Book, Manually detach the display: adım 2, 2 resimden 1. How to Detach the Keyboard on a Surface Book, Manually detach the display: adım 2, 2 resimden 2.
    • The next six steps show how to detach the display manually if you’re unable to power on the Surface Book.
    • Flip open the display as far as it will go.
    • Lift the device up and place it on its side, with the display facing away from you and the SurfaceConnect port facing up.
  3. How to Detach the Keyboard on a Surface Book, Bend a paper clip: adım 3, 2 resimden 1. How to Detach the Keyboard on a Surface Book, Bend a paper clip: adım 3, 2 resimden 2.
    • Straighten out one section of a paper clip.
  4. How to Detach the Keyboard on a Surface Book, Push the paper clip into the hole: adım 4, 3 resimden 1. How to Detach the Keyboard on a Surface Book, Push the paper clip into the hole: adım 4, 3 resimden 2. How to Detach the Keyboard on a Surface Book, Push the paper clip into the hole: adım 4, 3 resimden 3.
    • The Surface Book has an internal lever arm mechanism that can be manually actuated through an access hole in the vents on side of the display.
    • Insert the straight end of the paper clip at a 45 degree angle into the sixth hole from the left.
  5. How to Detach the Keyboard on a Surface Book, Release the mechanism: adım 5, 3 resimden 1. How to Detach the Keyboard on a Surface Book, Release the mechanism: adım 5, 3 resimden 2. How to Detach the Keyboard on a Surface Book, Release the mechanism: adım 5, 3 resimden 3.
    • Firmly push the paper clip into the hole.
    • This may take a considerable amount of force.
    • Once the internal lever arm is fully depressed, you can disconnect the display.
    • Pull the base away from the display to detach it.
    • If you are unable to detach the display from the base on this side, release pressure on the paper clip and try again.
  6. How to Detach the Keyboard on a Surface Book, Detach the second side: adım 6, 3 resimden 1. How to Detach the Keyboard on a Surface Book, Detach the second side: adım 6, 3 resimden 2. How to Detach the Keyboard on a Surface Book, Detach the second side: adım 6, 3 resimden 3.
    • The magnetic connections are prone to snap back into place, so hold the two halves apart.
    • With one side detached, pull firmly to pivot the display out to disconnect the second side.
    • If the magnetic connection feels extra strong and the display won't detach on the second side, keep the detached side separated with a spudger, pen, or pencil, and repeat the paper clip process on the other side of the display.
  7. How to Detach the Keyboard on a Surface Book, Remove the display: adım 7, 1 resimden 1.
    • Completely power down your Surface Book before opening it up for any repairs.
Sonuç
To reattach the display, align the magnetic connectors and allow it to snap into place.
Procedure didn’t go as planned? Check out our Answers community for troubleshooting help.
10 farklı kişi bu kılavuzu tamamladı.
Carsten Frauenheim
155.751 İtibar
439 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
23.658 adet Kılavuz yazıldı
7Kılavuz Yorumları
Yesss !
Respect !
Laurent Savarin - Yanıt
Hello,
Thank you for this tutorial.
Do you know if it works also for the latest Surface Book 3 in 15 inches size?
Philippe - Yanıt
merci beaucoup ce tutoriel m'a été très utile
Frank Pharose - Yanıt
Merci beaucoup pour ce partage, très utile!
Excellent travail!
bemba98 - Yanıt
These instructions are clear and concise - Worked perfectly! 5 stars out of 5! Thanks!
Caren Galloway - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 24
Son 7 gün: 187
Son 30 gün: 976
Her zaman: 95,528
