Ana içeriğe geç
How to Fix A Broken Makeup Compact Without Alcohol
Cura Mclemore
Cura Mclemore ve başka bir katkıda bulunan
En son May 24, 2023 tarihinde güncellendi
25 dakika
Orta
Use this guide to fix your favorite makeup compact. After a compact is dropped on the floor or has gotten old and cracked, this guide can help restore it. With a hot iron and kitchen silverware, you can press your powder back into place in no time.
Before using this guide make sure you're working on a clear surface, free of clutter and safe for the placement of a hot iron. Keep your hands steady while you're using the knife to remove the metal pan from the compact in step 4. Make sure the iron is unplugged and completely cooled before storage.
Neye ihtiyacın var
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. How to Fix A Broken Makeup Compact Without Alcohol, How to Fix A Broken Makeup Compact Without Alcohol: adım 1, 1 resimden 1.
    • Plug In the iron and turn the heat to the highest setting.
    • Caution: Be sure to place the iron on a flat, solid surface, away from plastic and other flammable objects.
  2. How to Fix A Broken Makeup Compact Without Alcohol: adım 2, 1 resimden 1.
    • Pour the broken powder into a plastic sandwich bag.
  3. How to Fix A Broken Makeup Compact Without Alcohol: adım 3, 1 resimden 1.
    • Use a spoon to break the powder down into a fine dust.
  4. How to Fix A Broken Makeup Compact Without Alcohol: adım 4, 2 resimden 1. How to Fix A Broken Makeup Compact Without Alcohol: adım 4, 2 resimden 2.
    • Take a knife and carefully remove the metal pan from the compact.
  5. How to Fix A Broken Makeup Compact Without Alcohol: adım 5, 3 resimden 1. How to Fix A Broken Makeup Compact Without Alcohol: adım 5, 3 resimden 2. How to Fix A Broken Makeup Compact Without Alcohol: adım 5, 3 resimden 3.
    • Pour the powder into the metal pan and begin to press the powder down with the spoon.
  6. How to Fix A Broken Makeup Compact Without Alcohol: adım 6, 3 resimden 1. How to Fix A Broken Makeup Compact Without Alcohol: adım 6, 3 resimden 2. How to Fix A Broken Makeup Compact Without Alcohol: adım 6, 3 resimden 3.
    • Turn the heat off on the iron.
    • Caution: Be sure to unplug the iron.
    • Use the heat from the iron to secure the powder in the pan.
    • Press down for 15 seconds at a time.
    • Repeat as needed.
  7. How to Fix A Broken Makeup Compact Without Alcohol: adım 7, 3 resimden 1. How to Fix A Broken Makeup Compact Without Alcohol: adım 7, 3 resimden 2. How to Fix A Broken Makeup Compact Without Alcohol: adım 7, 3 resimden 3.
    • Let cool completely.
    • Place metal pan back into the compact.
    • Now the compact is ready for use.
Bitiş Çizgisi
Cura Mclemore
145 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 270
