Ana içeriğe geç
How to Fix A Warped Frisbee Disc
Neye ihtiyacın var
  1. How to Fix A Warped Frisbee Disc, How to Fix A Warped Frisbee Disc: adım 1, 2 resimden 1. How to Fix A Warped Frisbee Disc, How to Fix A Warped Frisbee Disc: adım 1, 2 resimden 2.
    • Place the frisbee disc on a flat surface with the concave side facing up. Lay a towel down flat over the frisbee.
  2. How to Fix A Warped Frisbee Disc: adım 2, 1 resimden 1.
    • Take the bowl and fill halfway full with water. Microwave until water is boiling.
    • The bowl will be hot, so handle it with care.
  3. How to Fix A Warped Frisbee Disc: adım 3, 1 resimden 1.
    • Take the bowl with boiling water and place it on top of the frisbee and the towel.
  4. How to Fix A Warped Frisbee Disc: adım 4, 1 resimden 1.
    • Add a textbook as a weight to sit on top of the bowl.
    • Let everything sit for 1 hour
  5. How to Fix A Warped Frisbee Disc: adım 5, 1 resimden 1.
    • Remove any weights, the bowl, and the towel. Check to see if the disc is still warped.
    • If it is still warped repeat this process one more time.
Sonuç
The time taken to fix the warping on your frisbee may vary based on how thick the plastic is.
3 farklı kişi bu kılavuzu tamamladı.
Bryce Petersen
200 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 30-5, Green Spring 2015 Cal Poly, Team 30-5, Green Spring 2015 üyesi
CPSU-GREEN-S15S30G5
5 Üyeler
32 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 41
Her zaman: 10,528
