Giriş
Use this guide to fix the mouse if there is a double click problem on your Logitech G403.
Double clicking is a very common problem for G403. If your warranty is finished, you can fix the mouse by yourself, rather than buy a new one.
You will need a precision screwdriver set to fix the mouse. However, in case your screwdriver doesn’t work, you can look at these pages for help:
Don’t forget to unplug your mouse before you start.
Neye ihtiyacın var
Use a prying tool or your hand to take out both sides of the mouse feet.
10 farklı kişi bu kılavuzu tamamladı.
10Kılavuz Yorumları
Worked, thanks
Worked!!! I had this problem for years, even stoped playing valorant bacause of that. Thanks
