Ana içeriğe geç
How to Remove a Stripped Screw
Neye ihtiyacın var
Videoya Genel Bakış
  1. How to Remove a Stripped Screw, Use a different screwdriver: adım 1, 1 resimden 1.
    • Your screw is stripped, and your screwdriver is no longer sufficient. Before busting out the heavy hitters, try the following:
    • Use different screwdrivers. First try slightly smaller or larger head sizes, then a flat head screwdriver, to see if you can get it to catch on some part of the stripped screw.
    • If the bit doesn't catch the screw instantly, do not continue. Otherwise, you run the risk of further stripping the screw.
    • If either of these techniques are fruitful, congrats! Your screw is free.
    FixBot'a Sor
    Yorum Ekle
  2. How to Remove a Stripped Screw, Use a rubber band: adım 2, 3 resimden 1. How to Remove a Stripped Screw, Use a rubber band: adım 2, 3 resimden 2. How to Remove a Stripped Screw, Use a rubber band: adım 2, 3 resimden 3.
    • A rubber band can give you the extra grip you need.
    • Stretch a rubber band over the stripped screw.
    • You can also use a thin piece of fabric.
    • Insert a properly-sized screwdriver, and give it a turn.
    FixBot'a Sor
    Yorum Ekle
  3. How to Remove a Stripped Screw, Use a pair of pliers: adım 3, 2 resimden 1. How to Remove a Stripped Screw, Use a pair of pliers: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    Screw Extracting Pliers
    $23.95
    • If the screw head is accessible, try a pair of screw extracting pliers. If you can get a good grip, turn the pliers and the screw should turn along with it!
    • Once the screw is loosened a bit, you can probably back it out the rest of the way using a screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. How to Remove a Stripped Screw, Use glue: adım 4, 3 resimden 1. How to Remove a Stripped Screw, Use glue: adım 4, 3 resimden 2. How to Remove a Stripped Screw, Use glue: adım 4, 3 resimden 3.
    • Still stuck? Try adding a dab of superglue to the top of the screw.
    • Set your driver into the screw head, and allow the glue to dry.
    • Using a firm grip and downward pressure, give the driver a twist to remove the screw.
    • Don't forget to clean the remains of the glue from the tip of your driver.
    FixBot'a Sor
    Yorum Ekle
  5. How to Remove a Stripped Screw, Use a rotary tool: adım 5, 1 resimden 1.
    • If you were unable to remove the screw with screwdrivers, pliers, a rubber band, or super glue, then a rotary tool should do the trick.
    • Attach a thin cutting disk to your rotary tool. Before you cut anything, make sure the disk is secured well.
    • Make sure you wear protective goggles anytime you use a rotary tool to prevent injuries from flying debris and sparks.
    FixBot'a Sor
    Yorum Ekle
  6. How to Remove a Stripped Screw: adım 6, 2 resimden 1. How to Remove a Stripped Screw: adım 6, 2 resimden 2.
    • In this step, you will use the rotary tool to make a thin cut in the stripped screw that enables you to use a flathead screwdriver to remove the screw.
    • We recommend using a low power setting (we used 2 out of 6) to prevent damaging the rest of the device or the screw.
    • You want the cut to be deep enough that you can fit a flathead screwdriver into it, but thin enough that the screwdriver has something to grip.
    • Make a single thin cut into the head of the stripped screw.
    FixBot'a Sor
    Yorum Ekle
  7. How to Remove a Stripped Screw: adım 7, 1 resimden 1.
    • Use a flathead screwdriver to remove the screw from the device.
    • The size of the driver will depend on the size of the screw, but use the largest size that will fit in your cut.
    • If you cannot fit a screwdriver into the cut, use the rotary tool to make the cut larger. Make only small cuts; if you cut off too much of the screw, a screwdriver will not catch and you will not be able to twist the screw.
    • Wear eye protection and give your device a few good blasts of compressed air before reassembling it. The rotary tool can scatter loose metal shavings around the device, creating the potential for an electrical short if not blown clear.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Check out the video in the intro for some additional tips on dealing with stripped screws. Always use a high-quality screwdriver. Low-quality screwdriver material will cause damage to screws.
285 farklı kişi bu kılavuzu tamamladı.
Jake Devincenzi
119.397 İtibar
57 adet Kılavuz yazıldı
67Kılavuz Yorumları
I usually use the soldering iron, resting on the screw head dilation of the materials or any glue on the thread, but if the damage the screw head is large only with the idea of ​​same rotary tool.
Cleyton - Yanıt Paylaş
The soldering iron trick works great on screws that have Loctite! I have a red dot sight for my target pistol. I needed to remove a tiny hex head set screw. I almost broke the allen wrench and it still wouldn't budge. I applied heat to the allen wrench near the head of the screw and let it sit for half minute or so. The heat broke the loctite and the screw came right out! Thanks for reminding me and for posting this for everyone's knowledge.
Albert Albertson - Yanıt Paylaş
"To reassemble your device, follow these instructions in reverse order."
Yeah, that makes perfect sense... If you put the saw in reverse it glues all the buts of iron back onto the screw :-)
But other than that, this could be useful in some situations. Be careful,of the iron filings on your electronics!
koesper - Yanıt Paylaş
Haha, good catch! We've fixed the conclusion. Apologies to all who tried so very hard to follow these instructions in reverse.
Jeff Suovanen - Yanıt Paylaş
There's always the ultimate tool if it won't go out, the drill.
Of course you'll have to make new threads if you drill out a screw. However, as a "weapon of last resort", the drill always works.
Branko Dodig - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 142
Son 7 gün: 1,098
Son 30 gün: 5,003
Her zaman: 2,012,236
