Ana içeriğe geç
How to Fix a Broken Seam on Pants
Ben Blischke
Ben Blischke ve başka bir katkıda bulunan
En son January 8, 2025 tarihinde güncellendi
20 dakika
Kolay
Topluluk-Katkılı Kılavuz
A broken seam on your favorite pants can prevent you from using them, but did you know there is a simple way to fix the problem? Whether it’s a small tear or a larger unraveling, knowing how to repair it can help you keep your wardrobe looking great. We will teach you the step-by-step solution on how to get those pants back in shape!
  1. How to Fix a Broken Seam on Pants, Locate the repair area: adım 1, 3 resimden 1. How to Fix a Broken Seam on Pants, Locate the repair area: adım 1, 3 resimden 2. How to Fix a Broken Seam on Pants, Locate the repair area: adım 1, 3 resimden 3.
    • Identify the part of the pants that needs repairing and gather all the necessary tools.
  2. How to Fix a Broken Seam on Pants, Pin the area: adım 2, 3 resimden 1. How to Fix a Broken Seam on Pants, Pin the area: adım 2, 3 resimden 2. How to Fix a Broken Seam on Pants, Pin the area: adım 2, 3 resimden 3.
    • Use sewing pines or needles to pin the seam area and hold it together for the next step.
  3. How to Fix a Broken Seam on Pants, Clean the area: adım 3, 2 resimden 1. How to Fix a Broken Seam on Pants, Clean the area: adım 3, 2 resimden 2.
    • Once the area has been fixed with the pins, use a seam ripper to remove the old threads.
    • If there are still any remaining loose threads, use a pair scissors to cut them.
  4. How to Fix a Broken Seam on Pants, Start stitching: adım 4, 3 resimden 1. How to Fix a Broken Seam on Pants, Start stitching: adım 4, 3 resimden 2. How to Fix a Broken Seam on Pants, Start stitching: adım 4, 3 resimden 3.
    • Use a sewing machine to stitch the marked area.
    • Finish up the stitch by cutting any loose threads with a pair of scissors.
  5. How to Fix a Broken Seam on Pants, Finished and ready!: adım 5, 3 resimden 1. How to Fix a Broken Seam on Pants, Finished and ready!: adım 5, 3 resimden 2. How to Fix a Broken Seam on Pants, Finished and ready!: adım 5, 3 resimden 3.
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
Sonuç
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
Ben Blischke
9.298 İtibar
62 adet Kılavuz yazıldı
Ekip
INTERSPORT INTERSPORT üyesi
Community
22 Üyeler
161 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 38
Her zaman: 147
