Ana içeriğe geç
How to Fix a Broken XLR Microphone Cable
Neye ihtiyacın var
  1. How to Fix a Broken XLR Microphone Cable, How to Fix a Broken XLR Microphone Cable: adım 1, 3 resimden 1. How to Fix a Broken XLR Microphone Cable, How to Fix a Broken XLR Microphone Cable: adım 1, 3 resimden 2. How to Fix a Broken XLR Microphone Cable, How to Fix a Broken XLR Microphone Cable: adım 1, 3 resimden 3.
    • This guide will utilize a soldering iron. Please use a heat-resistant surface and proceed with caution.
    • Place the end of the XLR Cable on a clean, uncluttered surface.
    • Using a small screwdriver, unscrew the single screw near the top of the cable.
    • Gently pull apart the exterior metal from the internal mechanism.
  2. How to Fix a Broken XLR Microphone Cable: adım 2, 1 resimden 1.
    • Assess which connections have fallen loose. In this instance, the white cable is disconnected.
  3. How to Fix a Broken XLR Microphone Cable: adım 3, 2 resimden 1. How to Fix a Broken XLR Microphone Cable: adım 3, 2 resimden 2.
    • Assess whether or not there's enough exposed wire to reconnect loose cables. In this instance, the exposed cables are too short to effectively reconnect.
    • If the exposed wires are too short, use wire strippers or a razor to cut back the insulation.
    • Separate the wires.
  4. How to Fix a Broken XLR Microphone Cable: adım 4, 3 resimden 1. How to Fix a Broken XLR Microphone Cable: adım 4, 3 resimden 2. How to Fix a Broken XLR Microphone Cable: adım 4, 3 resimden 3.
    • Soldering irons are extremely hot. Proceed with extreme caution.
    • Solder each of the loose wires to the coinciding metal prong.
    • For more information on effectively soldering wire, please visit iFixit's Soldering Guide.
    • If necessary, use a thin wire to further manipulate the connection.
  5. How to Fix a Broken XLR Microphone Cable: adım 5, 2 resimden 1. How to Fix a Broken XLR Microphone Cable: adım 5, 2 resimden 2.
    • When the soldering is complete, reconnect the metal exterior to the head of the cable.
    • Using a small screwdriver, reattach the single screw.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Abbie Zajac
203 İtibar
1 Kılavuz yazıldı
Ekip
1Rehber Yorum
Great repair. If the cabke is broken I have a video on resolving that issue. https://youtu.be/E8CiX4cnc-U
DIM Tips - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 20
Son 30 gün: 102
Her zaman: 26,198
