Giriş
Solder bridges are an inevitable occurrence during the soldering process. This guide will show you how to fix a solder bridge and test your circuit after the fix.
A solder bridge can lead to serious damage to your device in the form of a short. A short is when too much current passes through a component, which can lead to device failure. This guide shows how to prevent a particularly dangerous short by clearing a solder bridge between the power and ground rails on a circuit board.
This guide involves the use of high temperatures when desoldering and soldering connections, so take appropriate precautions when the soldering iron is operating. You may need to repeat steps as necessary due to the nature of the desoldering and soldering process.
If you are new to soldering and desoldering, review the How to Solder and Desolder Connections guide.
Neye ihtiyacın var
Set the soldering iron to 300 °C (575 °F) and wait for the iron to heat up to the desired temperature.
Place the solder wick on top of the solder bridge and heat the wick using the soldering iron by pressing on top of the affected area.
Continue to apply pressure with the soldering iron to the solder bridge until the solder is melted and absorbed by the wick.
Connect the red (positive) probe to the Voltage and Resistance Socket.
Connect the black (negative) probe to the Common/Ground Socket.
Set the multimeter knob for continuity testing. This is typically labeled with diode/audio symbols.
To ensure the functionality of the multimeter, touch the two probes together and an audible beeping sound should be emitted.
Connect the black probe to the circuit board rail where one end of the solder bridge was.
Connect the red probe to the circuit board rail where the other end of the solder bridge was.
If the fix is successful, the multimeter should read "OL" on the screen, indicating an open circuit. There should be no beep, which means the rails are no longer connected.
12 farklı kişi bu kılavuzu tamamladı.
