Giriş
Keep your aging Mac from going obsolete by installing a patched version of macOS Catalina.
Note that installing future Catalina updates from Apple on your Mac is not supported by the patching tool, and you may be required to erase your drive and start this process over after doing so.
Neye ihtiyacın var
macOS Catalina Patcher can be downloaded from http://dosdude1.com/catalina/
Once the patching tool has downloaded, open the DMG file to mount it.
In the virtual drive, right click the "macOS Catalina Patcher", and click "Open".
If a warning appears saying that Apple cannot check the application for malicious software, click "Open" if it is an option, if "Close" is the only option, click it, then go into Security & Privacy in System Preferences, unlock the General tab and click "Open Anyway".
Continue through the prompts until you reach the "macOS Installer App" page.
Click "Download a Copy" to download an official macOS Catalina installer directly from Apple.
Click "Start Download".
If prompted, allow macOS Catalina Patcher access to your Downloads folder.
That’s it! You should now have macOS Catalina installed on your machine.
34 farklı kişi bu kılavuzu tamamladı.
21Kılavuz Yorumları
Hi, the Catalina install doesn’t work for me on a MBP early 2011. Have tried all of the three install alternatives.
Klas
a mi tampoco me ha funcionado y tengo un MBP late 2011. mi correo es luisguillermopalomino@gmail.com si quieres ponerte en contacto por si descubres la solucion
Hi there, I’m successfully running Catalina on an 8,1 iMac from 2008, so sweet! Only problem is that I can’t install some apps, like iWork/Pages or GarageBand. Is there any workaround for me to install Pages, especially? I hadn’t owned it before, so that option wouldn’t work for me.
Thanks in advance! :)
Install newer macOS maybe?
