Giriş
Use this guide to open your Logitech G Pro X Superlight wireless gaming mouse.
Opening your mouse gives you access to clean its internals, troubleshoot mechanical problems, or replace a part.
Neye ihtiyacın var
Slide your mouse's power switch down so it's in the OFF position.
Unplug all cables from your mouse.
Flip the mouse over so the feet are facing up.
Heat an iOpener and lay it on the mouse feet for one minute to heat the adhesive.
Use a spudger to carefully scrape up and remove any remaining adhesive bits.
Use isopropyl alcohol and a microfiber cloth to thoroughly clean all adhesive residue from the foot recesses. Allow the surface to completely dry.
Remove the feet from their backing and firmly press them into place.
Use a Phillips screwdriver to remove the six 4.5 mm‑long screws securing the bottom shell.
Use the point of a spudger to lift the locking flap on the top shell ZIF connector.
Use tweezers to gently pull the cable straight out of its socket.
5 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Hey there, thanks for detailed description.
I was a bit hard with the step below and broke the locking flap of the connector( What is the part number for the connector so I can purchase the donor?
