Giriş
Use this guide to open your Logitech G502 Hero wired gaming mouse.
Opening your mouse gives you access to clean its internals, troubleshoot mechanical problems, or replace a part.
Neye ihtiyacın var
Heat an iOpener and lay it on the mouse feet for one minute to heat the adhesive.
Use a spudger to carefully scrape up and remove any remaining adhesive bits.
Use isopropyl alcohol and a microfiber cloth to thoroughly clean all adhesive residue from the foot recesses. Allow the surface to completely dry.
Remove the feet from their backing and firmly press them into place.
Lift the weight door by its tab and remove it.
If you have weights in the compartment, remove them.
Lift the top shell straight up and remove it, making sure the main mouse cable stays attached to the bottom shell.
