Ana içeriğe geç
How to Open the Fitbit Charge 2
Neye ihtiyacın var
  1. How to Open the Fitbit Charge 2, Remove the watch band: adım 1, 1 resimden 1.
    • Before starting, take your Fitbit Charge 2 off the charger and power it down.
    • Remove the watch band on both sides.
  2. How to Open the Fitbit Charge 2, Heat the touch screen: adım 2, 1 resimden 1.
    • Heat an iOpener and apply it to the touch screen for two minutes.
    • The screen is not glued down, but the heat helps to loosen the touch screen assemly.
  3. How to Open the Fitbit Charge 2, Slide along the left edge: adım 3, 3 resimden 1. How to Open the Fitbit Charge 2, Slide along the left edge: adım 3, 3 resimden 2. How to Open the Fitbit Charge 2, Slide along the left edge: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    iSesamo Opening Tool
    $9.99
    • Insert an iSesamo into the gap between the touch screen and the watch assembly on the top left corner.
    • Slide the iSesamo along the left edge to the bottom left corner.
  4. How to Open the Fitbit Charge 2, Slide along the bottom edge: adım 4, 2 resimden 1. How to Open the Fitbit Charge 2, Slide along the bottom edge: adım 4, 2 resimden 2.
    • Slide the iSesamo around the bottom left corner.
    • Slide it along the edge to the bottom right corner.
  5. How to Open the Fitbit Charge 2: adım 5, 3 resimden 1. How to Open the Fitbit Charge 2: adım 5, 3 resimden 2. How to Open the Fitbit Charge 2: adım 5, 3 resimden 3.
    • Slide the iSesamo around the bottom right corner.
    • Keep sliding it along the right edge to the top right corner.
  6. How to Open the Fitbit Charge 2: adım 6, 2 resimden 1. How to Open the Fitbit Charge 2: adım 6, 2 resimden 2.
    • Slide the iSesamo around the top right corner.
    • Slide it along the top edge to the top left corner.
  7. How to Open the Fitbit Charge 2: adım 7, 2 resimden 1. How to Open the Fitbit Charge 2: adım 7, 2 resimden 2.
    • Place the iSesamo under the top left corner.
    • Feel free to reattach the watch band for this and the next step for a better grip.
    • Pry up the touch screen assembly by twisting the iSesamo sideways to create a gap and unhinge the plastic clips which are holding the screen in place.
  8. How to Open the Fitbit Charge 2: adım 8, 2 resimden 1. How to Open the Fitbit Charge 2: adım 8, 2 resimden 2.
    • Place the iSesamo under the top right corner.
    • Pry up the touch screen assembly by twisting the iSesamo sideways to create a gap.
  9. How to Open the Fitbit Charge 2: adım 9, 2 resimden 1. How to Open the Fitbit Charge 2: adım 9, 2 resimden 2.
    • Insert a spudger into the gap on the top edge of your Fitbit Charge 2.
    • Use the spudger to pry up the touch screen assembly.
    • Do not remove the touch screen assembly all the way yet—it's still connected to the motherboard.
  10. How to Open the Fitbit Charge 2: adım 10, 1 resimden 1.
    • Carefully fold the touch screen assembly in the direction of the bottom edge.
Sonuç
Opening didn’t go as planned? Ask our Answers community for help.
Adriana Zwink
56.777 İtibar
167 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
119 Üyeler
19.658 adet Kılavuz yazıldı
1Rehber Yorum
How do I get the daughterboard out?
Pospesel - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 22
Son 30 gün: 84
Her zaman: 5,943
