Ana içeriğe geç
How to Perform a Battery Cycle Reset
  1. How to Perform a Battery Cycle Reset, Download the app: adım 1, 3 resimden 1. How to Perform a Battery Cycle Reset, Download the app: adım 1, 3 resimden 2. How to Perform a Battery Cycle Reset, Download the app: adım 1, 3 resimden 3.
    • Download the Self Repair Assistant app (2.0.12)here.
    • You may be prompted with a "File might be harmful" warning. If so, select "Download anyway."
    • Open the "My Files" app.
    • Navigate to the "Installation files" tab on the left side of the screen.
  2. How to Perform a Battery Cycle Reset, Install the app: adım 2, 2 resimden 1. How to Perform a Battery Cycle Reset, Install the app: adım 2, 2 resimden 2.
    • Select the app on the right side of the screen.
    • If the app doesn't show up on this panel, skip to the next step.
    • Select "Install" to confirm the app's installation.
    • Skip the next two steps.
  3. How to Perform a Battery Cycle Reset, Rename the app: adım 3, 3 resimden 1. How to Perform a Battery Cycle Reset, Rename the app: adım 3, 3 resimden 2. How to Perform a Battery Cycle Reset, Rename the app: adım 3, 3 resimden 3.
    • If your app didn't show up on the "Installation files" tab, follow the next two steps to rename the file.
    • Navigate to the "Downloads" tab on the left side of the screen.
    • Long press the download file until an orange checkmark appears to the left of it.
    • Navigate to the bottom of the screen and select the "More" option.
  4. How to Perform a Battery Cycle Reset: adım 4, 3 resimden 1. How to Perform a Battery Cycle Reset: adım 4, 3 resimden 2. How to Perform a Battery Cycle Reset: adım 4, 3 resimden 3.
    • Select the "Rename" option.
    • Delete the .jar at the end of the app's name.
    • Your file should now appear in the "Installation files" tab.
  5. How to Perform a Battery Cycle Reset, Open the Galaxy Cal app: adım 5, 2 resimden 1. How to Perform a Battery Cycle Reset, Open the Galaxy Cal app: adım 5, 2 resimden 2.
    • Select the Galaxy Cal app.
  6. How to Perform a Battery Cycle Reset, Agree to the terms and conditions: adım 6, 1 resimden 1.
    • Select "Agree" to accept the Terms and Conditions.
  7. How to Perform a Battery Cycle Reset, Select the procedure: adım 7, 2 resimden 1. How to Perform a Battery Cycle Reset, Select the procedure: adım 7, 2 resimden 2.
    • Select the "Battery" icon.
    • Select "Calibrate" to continue.
    • If you want to perform a fingerprint sensor calibration instead, follow this guide.
  8. How to Perform a Battery Cycle Reset: adım 8, 3 resimden 1. How to Perform a Battery Cycle Reset: adım 8, 3 resimden 2. How to Perform a Battery Cycle Reset: adım 8, 3 resimden 3.
    • Select the "Start" button.
    • Select the "Start" button again.
    • Select "Ok" to finalize the battery cycle reset.
    • Wait until the battery cycle reset finishes.
    • You may need to reset your device for battery cycle reset to apply.
Bitiş Çizgisi
15 farklı kişi bu kılavuzu tamamladı.
Alex Diaz-Kokaisl
213.465 İtibar
1.040 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
23.648 adet Kılavuz yazıldı
46Kılavuz Yorumları
Thanks for catching that! I fixed the link in the introduction.
Arthur Shi -
I installed the galaxy cal app on an S20 and when opening the app I get a message to try again after getting new version
Pierre-Luc Thibeault - Yanıt
I have the same. Do you know how to fix this now?
Melanie Herget -
simply change your phone date between 2021 and 2022.
mightnire -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 82
Son 7 gün: 638
Son 30 gün: 3,345
Her zaman: 107,586
