Ana içeriğe geç
How to Remove Hard Wax from a Wax Warmer
MaCara Woods
MaCara Woods ve başka bir katkıda bulunan
En son December 12, 2023 tarihinde güncellendi
30 dakika
Çok kolay
The purpose of this guide is to remove hard wax from a wax warmer. Hard wax is used by both professional estheticians and regular, everday people. This technique can be used on any electric wax warmer. The process to remove the wax requires one to be exposed to hot temperatures. Therefore, heat-resistant gloves are suggested, but not required for this technique.
  1. How to Remove Hard Wax from a Wax Warmer, How to Remove Hard Wax from a Wax Warmer: adım 1, 2 resimden 1. How to Remove Hard Wax from a Wax Warmer, How to Remove Hard Wax from a Wax Warmer: adım 1, 2 resimden 2.
    • Plug in your wax warmer.
  2. How to Remove Hard Wax from a Wax Warmer: adım 2, 1 resimden 1.
    • Turn up the heat nozzle to the maximum temperature.
  3. How to Remove Hard Wax from a Wax Warmer: adım 3, 1 resimden 1.
    • Allow the wax to sit for a few minutes until fully melted.
  4. How to Remove Hard Wax from a Wax Warmer: adım 4, 2 resimden 1. How to Remove Hard Wax from a Wax Warmer: adım 4, 2 resimden 2.
    • Take a paper towel and popsicle stick and wipe up as much of the wax as you can.
  5. How to Remove Hard Wax from a Wax Warmer: adım 5, 2 resimden 1. How to Remove Hard Wax from a Wax Warmer: adım 5, 2 resimden 2.
    • Add a tablespoon of your oil of choice to the wax bowl (suggestions: coconut oil or olive oil) and swish it around the bowl.
  6. How to Remove Hard Wax from a Wax Warmer: adım 6, 2 resimden 1. How to Remove Hard Wax from a Wax Warmer: adım 6, 2 resimden 2.
    • Use another paper towel and popsicle stick to clean up the remaining residue.
  7. How to Remove Hard Wax from a Wax Warmer: adım 7, 2 resimden 1. How to Remove Hard Wax from a Wax Warmer: adım 7, 2 resimden 2.
    • Turn off the wax warmer and unplug it from electrical socket.
  8. How to Remove Hard Wax from a Wax Warmer: adım 8, 1 resimden 1.
    • Once the wax warmer is cool, proceed to wipe up any excess oil with a paper towel.
Bitiş Çizgisi
MaCara Woods
157 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 165
