Ana içeriğe geç
How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars
James Silva
James Silva ve 4 diğer katkıda bulunanlar
En son July 22, 2023 tarihinde güncellendi
40 dakika - 1 saat
Orta
Binoculars are somewhat delicate, and when used outdoors in dynamic settings, they can sometimes sustain damage, which can knock the two sides out of alignment, culminating in double vision. Small changes in the positioning of the prisms can result in significant differences in the vision of the binoculars, and binocular manufacturers often hide the adjustment screws to discourage owners from attempting to repair them on their own. This guide will demonstrate how to find the adjustment screws on a pair of Barska 10x50 WA binoculars and adjust them to align the double vision.
Neye ihtiyacın var
Aletler
  • Jimmy
  • 64 Bit Driver Kit
  • iFixit Opening Tool
    iFixit Opening Tool
  • iFixit Precision Bit Driver
  • iFixit Precision 4 mm Screwdriver Bit
  • 1.5 mm Flathead Screwdriver
  • JIS #0 Screwdriver
Daha fazlasını göster…
  1. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars, How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: adım 1, 1 resimden 1.
    • Remove the main J0 head screw in the center of the binoculars, using the driver with the 4 mm bit and J0 attachment.
  2. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: adım 2, 2 resimden 1. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: adım 2, 2 resimden 2.
    • Remove the top piece and the washers held under the middle screw.
  3. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: adım 3, 2 resimden 1. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: adım 3, 2 resimden 2.
    • Pull the eyepieces off the binoculars.
  4. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: adım 4, 2 resimden 1. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: adım 4, 2 resimden 2.
    • Remove the two side J0 head screws.
  5. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: adım 5, 2 resimden 1. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: adım 5, 2 resimden 2.
    • Remove the four J0 head eyepiece screws.
  6. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: adım 6, 1 resimden 1.
    • Remove the two eyepiece plates.
  7. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: adım 7, 2 resimden 1. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: adım 7, 2 resimden 2.
    • Pry apart the rear rubber covering on each side to expose the two back prism adjustment screws.
  8. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: adım 8, 2 resimden 1. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: adım 8, 2 resimden 2.
    • Adjust the two 1.5 mm flat head prism screws by slightly turning the driver.
    • Note: Look through the binoculars after each turn, and if the vision is aligned, you can stop at this step. If adjusting these screws does not align the vision, proceed to Step 9.
    • DO NOT tighten the prism screws too much, or you will crack the prism and permanently destroy it. Repairing or replacing the prism is beyond the scope of this guide.
  9. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: adım 9, 1 resimden 1.
    • Unscrew the two front objective lenses by hand.
  10. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: adım 10, 2 resimden 1. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: adım 10, 2 resimden 2.
    • Unscrew the two J0 head front screws.
  11. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: adım 11, 1 resimden 1.
    • Remove the two front plates.
  12. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: adım 12, 2 resimden 1. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: adım 12, 2 resimden 2.
    • Peel back the front rubber coverings on both sides.
  13. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: adım 13, 2 resimden 1. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: adım 13, 2 resimden 2.
    • Adjust the two front 1.5 mm flat head prism screws with small turns.
    • Look through the binoculars after each adjustment to see if it is aligning the vision, and repeat the adjustments until it is repaired.
    • You may need to return to Step 8 to fine-tune the other set of screws. All four prism adjustment screws must be in their correct positions to produce the correct view through the binoculars.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
James Silva
241 İtibar
1 Kılavuz yazıldı
Ekip
CSU Fullerton, Team S1-G3, Bruce Fall 2019 CSU Fullerton, Team S1-G3, Bruce Fall 2019 üyesi
CSUF-BRUCE-F19S1G3
4 Üyeler
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 35
Son 30 gün: 145
Her zaman: 5,467
